From the YouTube video "Wingcopter - first fully tilted flight with the new APM2.5"
Looks great. Anybody have details?
(via RCBill)
(via RCBill)
Thanks for the compliments! We took the Arducopter code and changed the motor outputs dependent on the tilt angle. The pilot has simply a knob to tilt the arms in to the angle he likes. The wincopter is fully controllable/flyable at each tilt angle and owning to the FC very stable too. It means that it flies also for example with a 45° tilt angle. There´s no need for extra control correction.
@Jonathan Hesselbarth Great work! best VTOL I ever seen.
Regarding davidbuzz question, the transition quad <-> plane once is triggered, Is it autonomous? or require your control over elevator and ailerons til its finished.
@Jonathan Hesselbarth - we'd love to know what ( if any ) software / code changes you've made to ArduCopter or ArduPlane to make this ingenious configuration "work"....?
Hi everybody!
@ Alejandro Martin Pirola - The hover time is around 8 minutes. During forward flight it should be possible to stay up longer than 20 minutes (if you fly slowly). I just loaded up two graphs about the electric power flow ->Link. The Propulsion of one motor is around 1,2 kg. The weight of the whole aircraft 2,4 kg.
@Jim Turpin - You're right, we had two prototypes before the current version V13CH. At the moment we're testing the aircraft to bring it ready for a serial production. I think we are able to sell the V13CH soon ;)
@Kim Skatun - Nice project at the RWTH Achen! We are students from the TU Darmstadt.
Regards
Jonathan
check out Maverix
@davidbuzz - ou're looking at the betaversion which is a different fuselage than the one shown in the above video. http://www.wingcopter.com/html/betaversion.html Thw one in the video above has servos for ailerons / elevator / and rudder. It looks like they have a couple different designs on their site. SUPER COOL, and I want one now. I wish there were some more build details.
@JimTurpin - their website says they only use 4 motors and 2 ailerons, its in German, but google translate will give a pretty good interpretation.... http://www.wingcopter.com/html/flight_controller.html
@davidbuzz - There's servos in the rudder / elevator. See this video: https://www.youtube.com/watch?v=a1TZANSuHCA
it uses sail winch servo/s to manage the tilt mechanism. it steers with 4x motors, and 2x ailerons, not using any active rudder or elevator . :-)
Awesome. I would like to know efficiency data. Hover time / Forward Flight Time. VTOL Propulsion weight / Equivalent Single motor propulsion weight.
Looking forward to know trade offs about having multicopter and plain capabilities together.
