What airframes are you flying with APM?
Here's what I'm flying with ArduPilotMega:
--EasyStar (default settings work fine)
3689379871?profile=original
--SuperStar EP (default settings work fine):
3689379917?profile=original
--Skyfun (default settings work fine)
3689379952?profile=original
--Skywalker (picture at top)
--And of course ArduCopter!
What airframes have you flown APM with? Any tips or changes needed?
  • Could not resist, while learning and developing I am "flying" a bread board with APM.
  • I'm pretty amused with your result and the stock Ardumega code.
    I added the Skyfun to my list. Flies great with APM's default settings.
    Check out the tight patterns in RTL mode today (circles are autonomous; the other stuff was me flying in manual):
  • Now for ArduPilot....
    Specs:
    WARP-4 Brushless (RCBL415-5 inrunner) no longer available
    APC 6X4 Sport Prop
    Blue 3s/30C 2200 mAh Lipo
    ArduPilot/V2 shield/AS sensor/FMA XY & Z ir sensors.
    This aircraft flys better than the post above: however, they both are great fliers. I have many (20+) one hour plus flights on the E* above and 1 on this aircraft.
    Plan to test ArduPilotMega in a SkyWalker that at present is in country, creared customs and should be here to me 1 or 2 December. After test and some tuning I want to install it in this 1981 Aquila Standard glider modified for electric several years ago. The aircraft in my avitar
    Joseph Schauber
  • These pictures were taken 9/29/2009
    of this house
    using this easy *
    AXI 2208-34 , APC 7X6 Sport Prop , TP 3s/15c 2100mAh at 3A cruise in 5-10 MPH winds
    Joseph Schauber
  • - Scratchbuilt Oshkosh Special 40" ( http://www.rcgroups.com/forums/showthread.php?t=1040899 ) in 6mm Depron
    - Towerpro Combo ( http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=... )
    Did some tests with APM but the throttle keeps dipping, most likely a calibration problem.. working on it =]
  • MPX Mentor
  • Putting the final touches on my Maja.
  • Multiplex Easystar
    Skywalker
    Wingdragon 3Ch
    Wingdragon Sportster
    Balsa Glider with 2meter wing span.
    NirtoPusher Plane with 2 meter wing span
    UAVX & UAVP Quadrocopter with self made frame.
  • Skywalker
    - Pitot is really easy to place in the nose in the air intake
    - cut the door open on the left side (when looking at the plane as a pilot). It makes it easier to connect the mini usb for maintenance.
    AIRSPEED_CRUISE is maybe a bit slow for this plane which is heavier than the EZstar.
    Otherwise it works very well
