3689596462?profile=original
I think we made the smallest and lightest GPS/QZSS GLONASS BeiDou receiver with HELICAL antenna in the world. This board designed for ultra small robots. Board size with build-in antenna 20x11mm Weight 1.5 gram.
3689596365?profile=original
MAX-M8Q Receiver features:
  • 72-channel u-blox M8 concurrent GNSS receiver GPS/QZSS L1 C/A, GLONASS L10F, BeiDou B1, SBAS L1 C/A: WAAS, EGNOS, MSAS
  • Sensitivity: Tracking  -167dBm  Nav 164 dBm
  • On-board Ultra low noise 3.3V voltage regulator and RF filter for noise blocking
  • Uart (Tx,Rx), and I2C interface
  • HELICAL antenna
  • Time pulse LED
  • Battery for HOT module start
  • Dimensions: 20x11 mm
  • Weight 1.5 gram
  • Fully assembled and ready to use
I think We will add test result next 3-4 days.
  • The right question is "Is this working at all"?
    I tried everything possible with the module, and the maximum amount of sats I managed to get was 5-6, and it was constantly dropping down to 4 and below.
    The only good thing about the module is the look and size, as for performance... it looks like a total failure.
    Please correct me if I'm wrong, anyone running the module with better results?
  • I wonder if the antenna works upside down. Have you got any test result?
  • How many pcs you need? About module you can write me email.
  • Will it also be possible to buy only the ublox module. I would like to integrate it on my flightcontroller.
    The modules are hard to get.
  • All orders shipped from Europa
    Board pinout
    3701744757?profile=original
  • Hi GSCShop,
    where is your shop/company located at?
    The "About us" page does not show any information.
    Where are you shipping from?
  • Thank you.
  • I will add pinout today there and to item description in the shop.
  • Hi there,
    I am still looking for the pinout for the Helix version.
    Unfortunately, I get no response to my emails to CSGShop.
    It should not be a problem to put the pin assignment available.
    regards Peter
  • Looking forward for testresults
