Yet another recovery system...
Here is a short video of what we have been working on this year...
UAV Ballistic Recovery System Development tests from LeteckyUstav on Vimeo.
Galaxy GBS 10 Mulicopter
UAV Parachute Ballistic Rescue System
Development  tests
www.galaxysky.cz
Certified aerospace testing facility
Institute of Aerospace Engineering
Brno, Czech Republic
June - November 2014
Designed and tested to
RTCA-DO-160 standards
Patent pending
coming soon ...
  • Doug: there is already a selection of CO2 systems, so we wanted to do something different:-)
    General advantages of the pyro-actuated system over CO2-propelled as I see them:
    - faster
    - lighter
    - more reliable
    Don't know about the price and safety - once you factor in the valve/pyro-actuator used to trigger the CO2 cartridge, I believe the things start to look differently.
    Basically - we believe pyro-actuation is the most viable concept ... and it is always better to have more solutions to choose from, right?
  • Hans: on the ground a safety pin is present that effectively short-circuits the pyro, preventing any current in the circuit that could potentially cause a deployment.
    Regarding the EMI issues (which are relevant only once the system is armed / in flight) the system is designed with these in mind, featuring optocouplers and other principles (sorry I am not and expert in this therefore can't give you more detail at the moment). If I use the automotive analogy again - one doesn't need to pull a safety pin prior to crashing in one's car, yet the airbags, belt pre-tensioners etc. will work. And personally, I am not afraid of these being triggered accidentally in the middle of a peaceful drive. Therefore - this can be done safely.
    For transportation in a commercial aircraft there will probably be a safety container for the pyro-actuator to assure compliance with the respective regulations. However, this is yet to be confirmed.
  • 400g is a good number ;-)
  • Also, how is the system made safe against accidental firing in what is a very RF rich environment?
  • Ok. With respect: How is your system made safe and armed? How do I travel by commercial aircraft if I equip my UAV with a system like this?
  • Ali: Thanks. Sure it can be used on fixed wing platforms. If you are able to fit it in (at the moment the outer dimensions are 100mm in diameter and 100mm height), it shall work even better than with the multirotor - simply because you typically have higher initial velocity when deploying the parachute in a plane. That will reduce the opening time of the parachute.
  • Thanks Hans. BTW there is a very good chance you have at least half a dozen exactly the same pyro-actuators in your civilian car ....
  • Good luck getting anyone sane to buy a system that uses pyro for deployment, whether it's ejection, or just cutting lines. Pyro is simply not suitable for the civilian sector.
  • Great!
    I hope it can be used on planes as well.
