Hi everyone,
3689685346?profile=originalWe're proud to announce that Zubax GNSS 2 is now available. Zubax GNSS 2 is a compact multipurpose high-performance positioning module interfaced via redundant CAN bus, USB, and UART. It includes a state-of-the-art multi-system GPS/GLONASS receiver, a high-precision barometric altimeter, and a 3-axis compass with thermal compensation. Zubax GNSS 2 supports variety of standard protocols, which ensures compatibility with most of existing software and hardware: UAVCAN (over CAN bus), NMEA 0183 (over USB and UART), and u-Blox M8 protocol.
Zubax GNSS 2 is the successor of well-received Zubax GNSS v1; it features an upgraded GNSS receiver (latest u-Blox M8Q), smaller form-factor (55x55 mm), and a higher gain antenna. Like it's predecessor, Zubax GNSS 2 features high noise resilience thanks to the RF shielding and good PCB design.
Our website contains tutorials that demonstrate how to use Zubax GNSS 2 with Pixhawk (PX4, ArduPlane 3.5.1, ArcuCopter master), with GIS software, and with non-UAVCAN enabled systems (e.g. lower-end autopilots).
3689685386?profile=original
Features
  • Operating temperature: -30 to +60 °C
Sensors
  • State-of-the-art concurrent GPS/GLONASS receiver u-blox MAX-M8Q
    • Full RF shielding of the GNSS circuits ensures reliable operation in high-EMI environments
    • 35 mm high gain patch antenna with large ground plane for reliable reception even in urban canyons
    • Analog front end with LNA and SAW ensures high noise resilience
    • Backup supercap enables low time-to-first-fix (a few seconds)
    • Up to 15 Hz update rate
  • High precision digital barometer Measurement Specialties MS5611
    • Altitude resolution 10 cm
  • 3-axis digital compass with thermal compensation
Interfaces
  • Doubly redundant UAVCAN
    • Continuous self diagnostic and failure detection outputs
    • Configuration
    • Can be used in non-redundant mode as well (one interface will be inactive)
    • Firmware update
  • USB
    • NMEA output for all sensors
    • Direct access to the u-blox module
    • Diagnostics and configuration via command-line interface
  • UART
Purchase
Zubax GNSS 2 can be purchased from Titan Elite, Inc. Please follow this link to place an order: http://titaneliteinc.com/titanoc/index.php?route=product/product&product_id=987.
Links
  • Lovely bit of kit! I was discussing the inclusion of an external baro within a GPS unit on another thread on here recently, and this definitely hits the mark! The pricepoint of this product however is what puts me off. If I was flying professionally, I'd definitely jump at this though. I have integrated a standard m8n (uart)/mag(i2c) with an i2c connected baro, all inside a (slightly modified) GPS puck on one of my quads, and this works beautifully for under $30 with APM 3.4dev. I can't really justify175 euros for one of these. Its a great product though - nice to see new sensors using digital bus for connectivity instead of basic UART.
  • Anyone who's struggling with the web store (it occasionally malfunctions during checkout, which happened to Justin), please reach to pavel.kirienko@zubax.com. The web store should resume normal functioning soon though. Sorry for the inconvenience!
  • It would be nice if it was sold with the case
  • DG, maybe you should consider switching to PX4 instead ;)
  • I'd love to try this, but with AC 3.4 stalled already by 3 months it probably won't happen, although I have 3.4 dev in the test quad; don't know if it has updated UAVCAN. I certainly hope we'll see 3.4 materialize this year, if ever.
  • Justin, there seems to be a transient issue with shipping indeed. We're looking into that; please check back later! Sorry for the inconvenience.
  • Looks like it is not possible to ship to Canada on the website.
  • I have flown the v2 module with ArduCopter (master) an can confirm that the new module is working nicely and performs very well. It is almost plug-and-play with APM: after setting the params BRD_CAN_ENABLE to 2 and GPS_TYPE to 9, it is auto-detected as primary GPS on next boot. One thing to note is the exceptional lock performance: it usually has a low-HDOP 3D lock well before APM has finished booting.
    Unfortunately, ArduCopter 3.3 still relies on a very outdated UAVCAN stack, hence there is no support for recent UAVCAN components in stable ArduCopter yet.
    @Olivier, yes, ArduPilot supports baro failover, plus you can choose which baro is your primary. I fly one of the earlier v1 versions of this GPS on a heli with the external baro as the primary.
    I don't have one of the v2 units, but I'd be surprised if it didn't work just as well as the v1
  • I like it using UAVCAN but I wish it was 3*3cm for small racing quads.
