Another Folding X8
Hi guys,
Been lurking for a few years with not much to add, but thought I might share my latest build with you. It is (yet another) folding quad, but in X8 configuration, with a few of my own ideas. This is the 4th copter I've built (all running AC code) and each one has been a learning curve, which I expect this one to be as well, although I hope I'm a bit closer to 'home'.
My application involves trekking through the bush, to eventually work on hilly, rocky areas with long grass often. So I needed a craft which would be small enough to carry easily, but then tall enough to land / takeoff in long grass. Also because there's almost nowhere level, I wanted independent legs (as opposed to helicopter type 'skids') which can adjust to uneven terrain and have a shock absorber in each, so that when it comes down if one leg touches down first it doesn't take the complete brunt of the landing. And also because I wanted redundancy I went with the X8 configuration (which doesnt lend itself to independent legs...). I also wanted it to fold up 'within itself', with no props sticking beyond the borders of the frame.
So this is what I ended up with:
Motors AX2810
ESC's Afro 30 amp
Pixhawk (a clone, unfortunately, because 3DR stopped shipping overseas as I wanted to place my order)
Prop to Prop (diag) is 770mm
Folded its 410 (L) 250 (W) and 150 (H)
AUW (with battery) is 3.3kgs
Although I have borrowed some of the folding frame ideas, the design is completely my own. I had the plates water jetted, and machined the rest (such as the gimbal) myself.
Here are some pics:
With Arms and legs opened
3691152317?profile=original
You cant see clearly from the pic, but the configuration is a square 'quad', I need it to fly equally forwards, backwards and sideways
3691152436?profile=original
Each leg has about 100mm of suspension travel
3691152369?profile=original
I used shock cord which I can easily adjust the tension of to get the correct balance, and the pivot point has small bearings to run on.
3691152330?profile=original
Folded...
3691152462?profile=original
The entire folding mechanism uses one 5.5mm socket to complete. All the other ends are 'captive' or can be held by hand. It takes less than 5 minutes to unfold it for flying
3691152391?profile=original
The gimbal retracts for transport, then moves out to clear props and legs during flight
3691152343?profile=original
I would appreciate your comments and advice. I've still got a fair bit of tidying up with wiring to go, and am still waiting on my 4S batteries to arrive. In the future I might change a few things (like making the legs a tad shorter), but in the mean time I need to start tuning it. I've only done one short flight in the back garden so far :)
Pete
  • Great progress Pete! I recently did some new really lightweight legs for a H8 I am working on. make work on your assembly if you are interested.
