Another Hexacopter Build
I started off small with a custom built quad and got the hang of flying multicopters...This just fueled the fire. After doing much research, attempting to build everything from scratch and failing, I decided to start buying components for my hexa. (I've also decided that I need a CNC machine so I can build my own components/parts, so that project is next in line...)
My intentions at the beginning of this project were to be able to lift a camera (from gopro size to dslr size) to take video.
Here is a rundown of my copter...
frame: Hexacopter + configuration (mashup of different parts)
controller/autopilot: APM1
motors: 2210N 1000kv
esc: Turnigy Plush 30A
propellers: 10x4.7, APC SF
battery:  Turnigy 3S 5000mAh
flying time: Currently unknown. Still tuning and working out the kinks. Will test shortly.
radio: Turnigy 9X
video/osd: eventually
other: Sonar, Xbee, Optical Flow, Attopilot current sensor coming soon
Misc:
Turnigy 9X: LiPo Battery
Camera Mount: x468 with mods (pics to come)
Supplies:
3690920218?profile=original
3690920295?profile=original
Boom Mount:
3690920245?profile=original
Motor Mount:
3690920323?profile=original
Power Disk (as I call it):
3690920373?profile=original
APM Mount:
3690920350?profile=original
Aft View:
3690920127?profile=original
Closeup:
3690920434?profile=original
Finished Copter:
3690920456?profile=original
Here is a quick video of my first flight. It hovers nicely at about 50% throttle. I still have to tune it and balance it out better, but not bad for it's first flight. I will also be checking flight times in the coming days. I'm also in the process of building my camera mount and will post pictures of that soon.
  • Hi there,
    Like your build. I've just started working with copters and looking at building my own in a few months time. Where do you get your frame parts if I may ask? I am interested in your arm mounts and and roto mounts?
    Further were did you get your gimble and landing frame. If I may ask what did you spend on such a build in total and what can this thing carry in weight?
    Look forward to hearing from you. Beej
