I have read about ardupilot and how it works. I would like to dvelop a pilot for a sailing vessel.
There are several points that make me doubt about using ardupilot, but maybe you can resolve them:
- with very low windspeed the output of a GPS in terms of heading are 0 (below 2 knots).
- that would leave the AP to rely on the gyros only that may suffer from substantial drift.
That would make the AP less dependant with the inaccuracies if the GPS.
Is it possible ti integrate this kind of sensor into the arduino pilot? And how would one do it?
Maybe there is already someone who has done that?
Cheers, and let me know !
Andreas
Your thrust is not like ours so you would need to re-work all the thrust stuff to get your sails to function correctly (whether you use an eclipse type rig or a more standard sail setup is your choice)
The GPS could prove to be an overworry if you are in a nice area for sats but before worrying about changing that part I'd get the basic controls sorted. Then hopefully the dGPS thread will be huge and have a working model so you can put units either end and have the master controller sending the GPS info into the APM.
As for your suggestions of magnetos I shall have to leave that to someone more knowledged in sailing and AP. Of course this is just my opinion but I think its possible with effort.
