APM 2.5 Super simple mode on ch7 or ch8
Hi,I set the super simple mode to ch7 / ch8 at the Mission Planner APM:Copter Pids.When I was flying to test it, nothing happend. It seems super simple mode doesn't work if set on ch7 opt or ch8 opt.In the instructions under "simple and super simple mode" it said this option is available for a 2 position switch but for a 3 position switch it is not available before version 3.1I use a 2 position switch so it should work.Has anyone tried this ?
  • I found a half solution !!
    Super Simple mode is enabled by setting the parameter named SUPER_SIMPLE to 1 (0 disabled default) in the Parameter List in the Mission Planner’s Configuration section.
    If you've done this and set "simple mode" to ch7 or ch8 opt it will fly in "super simple mode".
    If you want to fly in "simple mode" you need to set the SUPER_SIMPLE parameter to 0 and set the ch7 or ch8 opt to "simple mode".
    I know it's not logical but it works at least on my quadcopter.
    I'm sure this is a bug at the APM or Mission Planner !
    I haven't tried simple or super simple (permanent) on one of the 6 flight modes yet.
  • I just posted a note in the  3.0.1 thread about this in case there's more people there that have run across it.
  • Ditto - I have ch7 set to super simple mode.  Flipping the switch (Which I have confirmed multiple times is sending >1800PWM) is basically having no effect.  Seems like a bug unless we're all misunderstanding how this should work.
  • I've tried simple mode (not super) on ch7 on a 2 position switch and checked radio calibration but when I fly it did not work.
    Dit you try simple mode (not super)?
