Hello,
I have an APM 2.0 that connects fine over USB. Radio calibration in the GUI doesn't. All bars show zero/gray activity. Movement on any of the channels will not produce anything. GUI calibration isn't picking up anything.
If I run radio calibration in the CLI it seems to show something normal.
Setup > Radio calibration gives me all channels with averaging very close to 1100 | 1950
If I run the Test > PWM it appears all channels are moving smoothly between 11,000 and 19,536
When I run the GUI calibration every channel is exactly 3000 | 0
If I go to the Flight modes area, the mode CH5 is unresponsive and stuck at 0.
Again inside the CLI, the modes test seems to work fine toggling between certain modes that I can assign different modes at certain ranges using the controls on the radio.
The main HUD is showing disarmed if that helps. No response. I recall before I did an update the HUD was working great even with nothing connected to input/output. It wasn't showing disarmed on startup and I could move the APM around and see it moving on the HUD. I've tried disconnecting everything like before but still nothing on the HUD.
  • I'm apparently having the same problem as well.
    I have the following setup:
    - Spektrum radio AR400, (I've also tried Spektrum AR8000)
    - APMega 2.5+
    - Arducopter 2.9 Quad
    - Mission Planner 1.2.32 (I've tried 1.2.28)
    When I first connect to the APM using MissionPlanner10, I see the "Connecting MAVlink" retrieval of values from the APM on my screen work just fine.
    I am able to download code and use the CLI to interact with the APM and see that the printed results of the "setup" then "radio" radio calibration are:
    1: 1091  | 1892
    2: 1092  | 1892
    3: 1091  | 1896
    4: 1092  | 1891
    5: 1551  | 1152
    6: 1497  | 1498
    7: 1497  | 1498
    These values all seem reasonable given what I've read in the forums for a 4 channel receiver. The GUI radio calibration shows no happiness, an completes with the exercise with the defaults 3000: 0
    I've put a servo on the various outputs of the radio  and they individually work well, controlling the servo.
    I've put a oscilloscope on the APM inputs with the receiver connected to the APM and the signals look the same as when just connected to the radio - the PWM signal changes with changes in the transmitter controls.
    I have two problems as far as I can tell -
    1) the Planner GUI won't calibrate the radio in the APM (just as the original poster describes: no green bars moving)
    and
    2) the APM outputs 1-4 (corresponding to the 4 inputs) all have a simple square wave signal out of 1ms "on" and 1ms "off" instead of a PWM signal.
    Thanks for any help!
  • John, I'm having the exact same problem you described here.  How did you fix this??  Thanks!
  • Does anyone think this should be in the APM software section?
    It's difficult to tell if this is a software or hardware issue.
