Hi, guys. I try APM1, APM2 and 2.8.1, 2.7.3. They have same problem. If i change the servo position's param, only "tirm" had saved, but "min"and"max" must lost when APM reset!
When apm cut power or reset and reconnect, "min" ,  "max" must became "1000" and "2000"!!! The change was lost.
3690972826?profile=original
Why did happen this? Is it a bug? or i miss some options?
Please help me, thx!
  • I download code2.5.3 and try. It has same bug. too sad for this.
  • oh my god!!!
    I try change the parameter from configuration-advParameterList-...
    http://code.google.com/p/arducopter/wiki/TradHeli_Testing?wl=en
    change HS1_MAX, HS1_MIN,  HS1_TRIM, then "Write Params". Cut APM power connect again, NO~~~! just  HS1_TRIM be saved, HS1_MAX, HS1_MIN all back to 2000, 1000, no changed!
    Why happen this? //(ㄒoㄒ)////(ㄒoㄒ)//
