PixRacer Flight Controller: Everything seems OK on the APM Planner2 Transmitter Calibration page. 3 Flight Modes set up and PWM values recorded using the Tx Flight Mode switch. On APM Planner's "Flight Data" tab I can set the flight mode - but only with the buttons - NOT with the Transmitter.
One simple question:
When looking at the Flight Data, Flight Mode indicator, should this change to correspond to the Tx's switch selection and show me the current mode?
I can't see any problem in the set up. The Flight Controller (PixRacer) knows about the Flight Switch settings, through successful calibration, but gives me no indication of changing the mode via the Tx.
SBus used so no separate channel for carrying (Ch5) Mode info.
I can't be sure but just once I believe I saw a mode change when operating the Tx's mode switch??
I don't need a diagnosis - just confirmation the Tx mode switch changes should register on APM planner
Truly grateful if someone can take 5 minutes and give me a Yes/No, or whether some diagnostic might help.
