APM Power Up Errors
Hello,
   I'm getting pages of errors via the Arduino Serial Monitor on power up:
OK: PE3
EError: PE6 & PB0, Also check pin PE5,PE7 is not reading HIGH
Press Y to continue...
OK: PE7
EError: PE3 & PH1, Also check pin PE2,PE4 is not reading HIGH
(pages more)
Followed by PWM readings all the same, and an apparently endless loop.  I've not tried to upload anything because of the error condition, and I was unable to find any refererence to this condition.
I have the complete error log, if necessary.
Clearly, the USB is functioning (57,600, configured as documented)
After soldering and verifying the connections, I powered it up using the USB cable. On the APM, following LEDs are on: blue PPM solid, red power solid, yellow MUX solid; on the oil pan the blue "ON" led is solid, and the A and C LEDs are dimly lit after pressing "Y" a number of times in answer to the error prompt.  B does not appear to be lit at all.  Also, the RX and TX LEDs flash during serial communications.  I have also re-verified the soldered pins under a lense.
Initially, I had the MediaTek GPS connected, but have since unplugged it.  Nothing else has been connected (radio, servos, etc.).
UPDATE: I connected to the APM using the FTDI cable, and the response is the same.  Is this APM DOA?
Any thoughts?   Thanks,
                     -Dale
