Arducopter 2.7.2 is now in the mission planner and in the downloads area. Some positive reports on testing can be found in this discusssion by John Hanson.
Note: just as the release was going out an issue was found re support for the all Camera Gimbals on the APM1s (it doesn't work) and with 3 axis gimbals on the APM2 (2-axis works ok but not 3). If you're one of these people, please wait for 2.7.3 which will be out shortly.
UPDATE: 2.7.3 is now in the Mission Planner
Functional Improvements over 2.7.1:
Bug Fixes:
Code Cleanup:
As per usual PIDs are optimised for the 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
There is still some question on whether the default Roll/Pitch Rate P (0.175) is high enough (it was 0.185 in 2.7.1) and also some people feel the Throttle Rate should be higher (currently 0.300 but some say 0.330 or even much higher would be better).
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
Thanks and enjoy!
Permalink Reply by Kevin Brown on September 1, 2012 at 8:11am Very cool I will try in my Y6 today
Permalink Reply by den on September 1, 2012 at 8:59am I used APM2 2.7.1 firmware, DMP is enabled in the CONFIG the APM2 can start OK,But APM2 will crash starting when I enabled 2.7.2 CONFIG “# define DMP_ENABLED ENABLED” , what caused that ?
Den,
ok, thanks for the report. I'll check that out.
Permalink Reply by den on September 2, 2012 at 6:06am I enabled 2.7.3 firmware CONFIG “# define DMP_ENABLED ENABLED”, APM2 still crash when it staring :-(
Permalink Reply by Peter Chaffe on September 1, 2012 at 12:17pm Ok Just been out and tested, all good so far, slight tendency to climb in baro alt_hold (over 22 ft). Sonar alt_hold (below 22 ft) perfect.
Too dark to test auto.
RTL fine.
Decending when slow yaw is input,(in alt_hold) that problem has vanished, so now fine.
Still no dataFlash, reported in cli <dataFlash not inserted> APM2.5
Peter, I'm not seeing any dataflash issues on any of my APM 2.5 boards with this release. I think there may be an issue with the dataflash chip on your board. If you need onboard logging (I tend to use telem logging instead), you might want to send that board back.
Permalink Reply by Peter Chaffe on September 1, 2012 at 1:22pm Hi Chris,
Have modded the apm board, see the pcb strip held in position by the friction of mounting on spare header pins. the strip lightly holds in place a piece of breathable foam over the baro sensor.
See apm is also mounted on foam, also with foam under each clamp makes for hopefully a completely vibration free mounting, can't say I've seen any improvement due to the soft mounting, maybe because the props are well balanced! Not sure.
I'm in the uk, got my boards from Martin (BuildYourOwnDrone) Are you saying i should send the board back to him or to DiyDrones?
Ah telemetry, yes! 2.4ghz xbees! one not working, one might be, they weren't too kind! resulted in a burned out apm1 and oilpan! those were the days! Don't want to do a rerun of that scenario! What are the alternatives? I use uhf r/c as standard now so 2.4 ghz telem is no problem for me freq wise...
Peter
That baro cover looks fine. As for telemetry, you definitely want to go with the 3DR radios instead. Half the price, longer range, don't brick, etc...
You'd have to coordinate any return with the store you bought the board from. But if you're switching to telem logging (much more data, better analytics), you won't need the onboard chip so you'll be fine with your current board. (BTW, I'm assuming you can't erase the dataflash from the CLI either, yes? If you can do that, you should try to see if it clears things up).
Permalink Reply by Peter Chaffe on September 1, 2012 at 1:47pm Well the strangest thing is that on first power up from new, install and config, the dataFlash was being detected, and the first flight was recorded, I used MP cli to erase the flash for the next session. Since then the cli has always reported "Not inserted" message. There was one exception, when I loaded one of the v2.72beta versions it detected the dataFlash once, no logs, so did an erase and it said erase successful, since then I always get the "Not inserted" message.
Will look into the 3dr radios...
Peter
Peter,
On the APM2, I've found that sometimes it doesn't detect that it's inserted but if I jiggle it around a bit it's ok.
Permalink Reply by Peter Chaffe on September 2, 2012 at 2:34am Hi Randy, I should have mentioned, its the apm2.5 version with on-board dataFlash ic.
Peter
Permalink Reply by John Campen on September 7, 2012 at 8:48am Peter, See this post and threads about discussions on dampening issues.
http://www.diydrones.com/profiles/blogs/rubber-suspended-mounting-o...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
24 members
185 members
1295 members
687 members
Powered by
