ArduCopter 2.9 / 2.9.1 released
ACRO bug (fixed in 2.9.1b): while doing flips in ACRO mode, if you switch to Stabilize while inverted your throttle will go to minimum.  To regain throttle control you need to switch back to ACRO then back to Stabilize again (i.e. switch to stabilize twice).  You never lose control of roll/pitch/yaw.
Loiter/AltHold/Auto/RTL bug: if you switch into these modes with throttle at zero motors will go to minimum until you raise the throttle.
Auto mode altitude bug (fixed in 2.9.1b): setting a waypoint altitude greater than 320m over home altitude may wrap around and instead be interpreted as a low altitude.
ArduCopter 2.9 is now in the mission planner and the downloads area!
The major improvement is we use inertial navigation to improve altitude hold.  This increased reliance on the accelerometers means you must do some additional set-up before flying:
1. Perform the new accelerometer calibration in the mission planner (video).  The auto-trim metho has also changed (video).
3690987999?profile=original
2. Add vibration dampening foam between your frame and the APM.  Some suggested materials: DuBrogelhk foam.
3690988058?profile=original
 3. If upgrading from 2.8.1, modify the throttle and altitude PID values:
  • Increase your Throttle Rate P, reduce I to zero, increase D
  • Increase Altitude Hold P, reduce I to zero
  • Tune Throttle Accel P and I terms but try to keep P about 1/2 the size of I
3690988113?profile=original
Here is the list of major changes (a more detailed list can be found in the release notes):
  • Alt hold using inertial navigation (Leonard, Randy, Jonathan)
    • AUTO_VELZ_MIN, AUTO_VELZ_MAX parameters control the max climb/descent rate for the autopilot (cm/s)
    • PILOT_VELZ_MAX controls max climb/descent rate for the pilot (in cm/s)
  • Landing improvements (Leonard/Randy).  Copter will descend to 10m or until an object is sensed with the sonar.  Then slows to 50cm/s descent (speed can be adjusted with LAND_SPEED parameter). (video).
  • Surface tracking with sonar (Randy/Leonard).  Copter will attempt to maintain current distance from objects in front of sonar regardless of altitude.  Only used in alt-hold and loiter, not used for missions.  Sonar can be enabled/disabled with CH7 switch. (video)
  • Failsafe improvements (Randy/Craig/John Arne Birkeland) including bug fixes, additional check for PPM encoder failure and implementation of battery failsafe.  Set-up instructions are here.
  • Mediatek gps driver accuracy improvements and use of SBAS [Craig].  Instructions on upgrading your mediatek to firmware 1.9 are here.
  • Traditional Heli improvements (Rob) including (a) bringing heli code back into the fold, (b) enabled rate controller (previously only used angle controllers). (c) fix to rotor speed controllers - now operates by switching off channel 8.  (d) allow wider collective pitch range in acro and alt hold modes vs stabilize mode  (e) bug fix to allow collective pitch to use the entire range of servos
  • Acro trainer (Leonard). Copter will return to be generally upright if you release the sticks in acro mode.
    • ACRO_TRAINER : set to 1 to enable the auto-bring-upright feature
    • ACRO_BAL_ROLL, ACRO_BAL_PITCH : controls rate at which roll returns to level
  • Camera control improvements (Randy/Sandro Benigno):  (a) AP_Relay enabled for APM2  (b) Trigger camera with CH7 or DO_DIGICAM_CONTROL command  (c) Allow pilot override of yaw during missions and fixed CONDITIONAL_YAW command.
  • PPM sum support for transmitters with as few as 5 channels (Randy/Tridge/John Arne Birkeland).
  • Performance and memory useage improvements (Tridge).
As per usual PIDs are optimised for the 3DR/jDrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
Special thanks to our testing team lead Marco and the dedicated bunch on the 2.8.1 release thread who put their copters at risk while testing the pre-release version.  Some of their videos are here: 1 2 3 4 5 6 7 8
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
  • This reply was deleted.
      Roberto,
           It's better to raise support issues in the APM Forum.  It's very bad idea to remove the foam over top of the baro.  Who ever gave that advice is misleading you I'm afraid!
  • @randy, i am flying a 3DR qaudcopter with arducopter 3.0.1. In mission planning whenever i use a TAKEOFF command, the command following this TAKEOFF command is not executed. otherwise all mission planning commands are being executed in sequentially correct manner. The quad keeps loitering after reaching TAKEOFF altitude. my RTL and LAND are within 2m accuracy of HOME. The auto flight of quad is otherwise highly accurate and beyond imagination.
      Ravi,
           My guess is that the copter is not quite reaching the altitude target of the takeoff command.  Perhap try raising the Altitude Hold P value a bit.  The default is 1.0.  Perhaps try 1.5.
      • thanx randy, will try that.
  • Dear Randy,
    I'm having this yaw issue where when I yaw at a slow constant rate for 2 or 3 seconds (stick fixed), then the yaw rate of the quadcopter suddenly increases, requiring me to counter yaw to save it. The result is ugly flying. Below is a very short video clip I made demonstrating the issue. I hope somebody recognizes the problem and can provide some help. Thanks.
    https://www.youtube.com/watch?v=WaGUlHytcQE
    I haven't touched my yaw PIDs.
    My transmitter does not have expo on the yaw channel.
    I'm using quadcopter firmware 2.9.1b with an X frame.
  • Randy,
    Would it be possible for you to take a look at my friends hexacopter log. His copter flew away over the ocean out of site, then somehow decided to come back and crash next to him. He posted the question here: http://diydrones.com/forum/topics/hexacopter-takes-off-on-its-own-a...
    but never got an answer.
    Thank you!
  • My Tricopter altitude hold is no longer working. In altitude hold I can add full throttle and the copter descends to the ground. I can cut the throttle off, and it still descends to the ground at the same slow rate. Loiter is the same. Stabilize mode works normally.
    It worked fine yesterday. I did have a crash caused by a folding arm. I broke a wooden arm and had to replace all the props, but otherwise the damage was minor. I can't image what I could have damaged to cause such a strange behavior. The Baro sensor couldn't have been damged in a crash, it is protected be foam inside a case.
    Has anyone seen something like this?
  • Unfortunately I managed to change enough settings enough to make the auto landing rather shaky, the copter will loose altitude fast then correct going up etc, while before it was rather nice ie slow and smooth.
     Any idea of which settings would be the usual settings?
     Thanks a lot
  • Does anyone else have a problem of not being able to set the WPNav parameters? I would like to speed the quad up a bit but they seem to be set and nonadjustable? Am I missing anything?
  • Seems the 3.0 rcxx info is spread all over the place. Think we are up to rc5 now so I may give it a go.
    Is there a quick start guide anywhere of things I need to be aware of when switching from 2.9.? (non x.y).
    Will the MP give me the choice of H frames (need quad reversed motors)?
