Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Nice, it's best then ever! Congrats guys!
Where do we find log options in this release?
Barrett,
     We've had to remove the CLI because we were running out of flash space.  Instead you can download the logs from the MP's Flight Data screen's DataFlash Logs tab.
The CLI's motors test has been moved to the MP's Initial Setup > Optional Hardware section.
The CLI's reset (which resets all parameters to their factory values) has been moved to the Config/Tuning > Full Parameter list.  Although when I tested it a couple of days ago that wasn't working (it's a mission planner issue).
Thanks Randy. I found the download section. I was wondering how you now enable/disable items, i.e. imu, att, ctun, etc..
Barrett,
    Aha.  So it's possible to use the drop-down in the standard params screen of the mission planner to set the LOG_BITMASK parameter but the user doesn't get complete flexibility in what logs are enabled disabled.  So we need a new feature in MP which allows more fine grained control.  Issue for MP added!  Thanks for the report.
Awesome work Randy and the rest of dev team! Look forward to testing out new features and improvements!
Wow, exciting! So many improvements and new features confirms ArduCopter as an absolutely outstanding firmware, thanks and well done for all the hard work in getting this all implemented and tested!
You guys should be proud.
Thank you all ! Great team and great work! I have just upgraded the firmware but no time to test.
Excellant !
Hi Randy,
individual motor test: is it automatic (only to try correct spin motor direction) or it can allow me to control throttle manual every individually motor ? (for example to do individually dynamic balance motor/propeller)
Ciao - Giuseppe
Sweet!  Can you adjust RC_FEEL_RP via channel 6?
Time to test this new firmware. Thanks Devteam!
We need your test, fly safe and leave your report, thank you!
What could potentially create significant differences compared to the 3.1 is "EKF" and "Onion", so first do your tests at low altitude for Stabilize, Acro, Alt-Hold and Loiter (in this sequence).
One thing at a time, star and verify the "Stabilize" mode and see if the quad is stable, if so switch in Alt-Hold and see if the quad is properly locked in height, if all is ok switch in Loiter and check if all is ok.
If this three mode are well tuned it's time to check the other (Auto, etc.).
