Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
FYI.... WAAAAAAyyyyyy back in this thread somewhere I posted a problem about and issue were after going to 3.3 from 3.2 my teesny and lue script for my taranis telemetry was broken. It worked fine until I fired up a GCS station the instant I did that and connected the Taranis telem acted weird... useless. I FINALLY figure out it was because I needed to snip the red wire [ and I didn't blow up yea!!] which was the TX from the teensy RX on the tellem 2 on the pixhawk. Now it seems to work fine. If anybody knows why that is I would sure like to know!
Can someone please tell me how to skip just the gyro calibration pre-arm check? If I set pre arm check to '0' that disables all of them [ compass etc ] but all I want to do is skip just the gyro. I need to do this to arm on a moving boat until 'boat mode' gets the green light in 3.4. I hope...
https://github.com/diydrones/ardupilot/blob/ArduCopter-3.2.1/ArduCo...
ARMING_CHECK_INS = 0x10
Although note this skips all the INS checks including accelerometers.
Also note that in 3.3 these checks were specifically strengthened to fail pre-arm checks if the FC is moving over a certain threshold when arming such as on a choppy boat, as if this is allowed then as I understand it the FC can't then keep attitude control. In other words, bypassing this is a Very Bad Idea :)
Thanks. Yea I agree probably not a good idea. Guess I'll wait for a better solution in 3.4
I'm still encountering a similar issue with the Geo Reg Images utility in MP-1.3.32. Pre-process appears to only work for me when 'Use AMSL Alt' is unselected. If this is selected, the utility prints the error "Log file problem. Aborting". I'm still using AC3.2_RC10, and wondering whether there's been a change in the position (log offset) of the AMSL value in the logs?
@Glen M, Thanks for that. I have worked out how to use U-Centre. I can change the baud rate and then reconnect. The comms link is flashing green and I can read the data in the text window. . I can see the sat data, etc after re-connecting. Once I disconnect and lose power. The baud rate goes back to 57.6k.
Can I briefly take the discussion back to the M8N? I have bought one from FoxtechFPV and have found it much less sensitive the 3DR ublox indoors, but able to obtain more satellites outside. Previous discussions have talked about the configuration file for U-Centre. I have connected to U Centre and can talk to the GPS. Everytime I change the baud rate to 38400 and save the configuration and disconnect it, it reverts to 57600. I'm not sure if I am doing something wrong or it has no battery for flash.
Is there a command string that APM and Pixhawk write to the compass to configure it? As well, what is the setting to turn on all of the satellite networks for the M8N?
Thanks,
Joe
By the way, the GPS driver is suppose to work at baud rates higher than 38400 although I have never tested that this works reliably.
The reason your config isn't saving on the m8n is because you are unable to write to the rom after changing the baud rate, since u-center will still be connected to the gps at the original baud rate.
The way I do it, is make all of the config changes except baud rate, write the config to rom, then change the baud rate to 38400 in the gps config, then in u-center change the baud rate you're connected to the gps at to match. You will then be able to write the changes to the rom. You can see when you're connected in u-center when there's a green dot down the bottom somewhere that flashes when you bring up a new page in the config or try to write anything. When it's not connected, or has a baud rate mismatch, changing pages in the config doesn't make the dot flash.
Hope that makes sense!
Hi William,
if you add a log I will take a look for you.
1
2
3
4
5
of 262 Next
