There seems to be a problem with my Oilpan/shield. When i connect it up to the configurator, and look at the artifivial horizon, the roll rate seems very slow ato respond. When i roll my copter and put back to level, the artificial horizon slowly turns even though its already leveled. Compared to the pitch and yaw which responds instantaneously.
Is it a propblem with the roll gyro or my connectors are loose? Have been trying to figure out the problem for close to a month already. When i did try to fly the roll is very sensitive and always trying to flip. I only manage to get it up in the air once or twice and after that it wont anymore.
Any help would be great. Im uploading the video i took of the configurator, i'll attacj once its done.
Khairul
Tags:
Permalink Reply by k.rusydi85 on January 13, 2011 at 11:02pm The Video:
did you reset the eeprom and otherwise run through all the CLI setups, including accel offsets?
BTW roll and pitch are the same chip. It's impossible for one to work and the other not.
Permalink Reply by k.rusydi85 on January 13, 2011 at 11:47pm
Permalink Reply by k.rusydi85 on January 14, 2011 at 7:27am "I read abt the 200k resistor issue on the magnetometer, could that be affecting the oilpan?"
no, it's just the magneto
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
