I've just released ArduPlane 2.62
The main reason for this release so soon after 2.61 is to fix elevon mixing. That was broken completely in 2.61. My apologies to everyone with an elevon plane!
Other changes in this release:
Happy flying!
Tags:
Permalink Reply by James masterman on September 12, 2012 at 8:34pm Thanks Andrew, you are a machine!
The remote APM rebooting sounds good. My APM is buried in my airframe, so this will be useful. Will there be a reboot button on the mission planner to send the message?
Also can't wait to try out the ESC fix. My turnigy trust 40A ESC will sometimes not boot correctly.
Michael could certainly add one. I've added it into MAVProxy for now.
Cheers, Tridge
Permalink Reply by Gábor Zoltán on September 12, 2012 at 9:18pm
Permalink Reply by Perecastor on September 12, 2012 at 11:00pm Thannks a lot Andrew ^^
I was thinking that i was crazy ....
I give a lot this morning and come back for feedback ^^
Permalink Reply by Perecastor on September 12, 2012 at 11:47pm Seems better but still having roll problems in stabilize and FBWA ( plane want to turn left when it's 100% leveled ).
I'll give a try/fly when the weather is better ( raining day today..... ).
But again, thank for the quickly support! your are a boss !
Permalink Reply by Mike Mac on September 13, 2012 at 3:13am Has 2.92 fixed the telemetry painfully slow linkup bug that 2.61 has?
Permalink Reply by Asaak on September 13, 2012 at 6:39am Hi all!
I just updated to this last firmware and somehting really strange happen. I was going to perform a radio calibration but I realised that there is a huge lag between my actions and the response on the APM planner...for example, when I move the throttle stick it take like 7-8 seconds to show the bar moving up and down on the calibration menu. Same happen on flight stats, when I move APM 2.5 around it shows in the panel really really slow and with a huge lag! It was working yesterday night with 2.61...
Any ideas??
thanks!!
Permalink Reply by Asaak on September 13, 2012 at 7:56am I forgot to mention but, I did the usual things on this situation : reinstall firmware, reset factory, reinstall APM Planner, and even try it on another computer. Same result.
I covered the baro sensor as you explain on the wiki. Is it possible that this has something to do with it??
Thanks!
I am having the same problem on an APM 1/2560. My system is not functioning as it did on 2.6 . I am going back to 2.6 for now
Did you erase the eeprom first? (CLI setup/erase)
Yes. As Asaak said everything seems to be moving in slow motion. I have another system with an AMP 2.0 running ArduPlane V 2.5 and will wait before upgradeing firmware to get the nav improvements.
Asaak - Question Have you resolved your problem? If so, what resolved it?
I am still having major problems with AP 2.62.
First :
Just to check my hardware I loaded Arducopter 2.73 without erasing or anything else. Arducopter loaded without problems. After loading I went to flight data and checked out the HUD action. The hud follows roll, pitch, and Yaw almost instantaniously. Also Transmitter calibration using tlementery was normal. OK the hardware is fine.
Second :
I did the exact same thing with ArduPlane 2.62 on the same hardware and guess what . Snails pace on Hud reaction to Roll, Pitch, and Yaw. There seems to be a major problem with the Mavlink system and 2.62 in general. Using the CLI calabration and testing of the hardware A to Z is normal. The numbers on all tests Roll, Pitch,Yaw,Compass, PWM, and Passthru follow inputs to the letter with no visable lag.
Help any one?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.207 members
58 members
24 members
1355 members
88 members
Powered by
