I've just released ArduPlane 2.67
This release fixes a number of important bugs, as well as adding a few new features.
This release changes how the level parameters are stored in EEPROM, so it is very important that you re-level your plane after upgrading if you have MANUAL_LEVEL set to 1.
The key changes in this release are:
The new accelerometer calibration code that Randy did is particularly interesting, as it gives us a way to get the accel calibration much more accurate along all 3 axes, which should improve the attitude solution somewhat. It is not properly documented yet, but if you are feeling adventurous then try running the CLI and running the "accel" command in the setup menu. This replaces the normal levelling process.
Happy flying!
Cheers, Tridge
Tags:
Permalink Reply by Gábor Zoltán on November 21, 2012 at 5:49am
Permalink Reply by Gábor Zoltán on November 21, 2012 at 6:26am Thank you Tridge! :)
Hi Gabor,
I've now released 2.68 and I've checked that flash logging is working. Please let me know if it doesn't work for you!
Cheers, Tridge
Permalink Reply by Gábor Zoltán on December 4, 2012 at 1:08am Hi Andrew,
Thank you very much! :)
I will, as soon as my LRS arrives. (should be here till the weekend.)
Thx again,
Gábor
Permalink Reply by Leo Hogg on November 21, 2012 at 5:49am Thanks Tridge, 2.67 has fixed the differential aileron.
I re-calibrated the radio with diff set (on Ch1 & 5). Is that right or should I calibrate before diff is set to show it full PWM on those channels?
Will the APM also use this diff for automatic modes?
@Leo,
Good to hear its working!
Letting APM know the full radio range does make sense.
the APM treats the secondary aileron the same for all modes except manual, so it should work fine for auto mode. Note that I don't fly with a secondary aileron on any of my current planes, so if you have any additional notes or suggestions for the wiki docs please add them in the notes at the bottom of the page.
Cheers, Tridge
Tridge, it works very well (on the ground so far), I had to reverse my second aileron channel (CH6 in my case) in the MP and then all was well, both ailerons respond to roll in manual and in any of the other modes.
Spoileron (both ail's up) works well in manual but when switching to any of the other modes the second aileron channel offsets down about 30%. The CH6 status however stays 1663ms with both on so not sure why that is.
Permalink Reply by Djalma C Jr on November 21, 2012 at 6:07am Great News!!!! Congratulations!!!!
Permalink Reply by Gábor Zoltán on November 21, 2012 at 6:22am
Permalink Reply by Szilard on November 21, 2012 at 12:00pm I think yes, as far as I can see that in this patch:
http://code.google.com/p/ardupilot-mega/source/detail?r=e69108e7f56...
Is it a simple 180° reverse?
yes, I just reversed the vector for output in MAVLink after someone pointed out the convention is the other way.
Cheers, Tridge
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1286 members
87 members
39 members
24 members
5 members
Powered by
