Ok, here is another problem Ive spotted in the mind field of hardware issues and for people who continually bang their heads trying to fix them through PID tuning. .
If you have a housing that is covering over all of your electronics such as a plastic container,.. then when you descend or ascend quickly the pressure inside the container changes and gives your barometer an false reading.
For example if you descend quickly the pressure increases inside the container making the barometer think that you are descending faster than you actually are. So the APM will try to compensate this out and try to increase the throttle and this probably cause a bouncing behavior some people are finding happens .
Some may argue that the barometer cant be this sensitive, but I beg to differ because the pressure variation it can sense for the pressure variances in altitude that it works off is very fine. The pressure change inside the container even for horizontal flight will be enough to for it to sense the changes of pressure in the container.
This also includes pressure zones around the incoming and out going air stream around the props if they are to close to the container or even if you have an open center frame the pressure zone around the props can possibly still affect the barometer
I'm considering some fixes for this such as a tube that has a H tube branch at its end and that sits above or below the center board.
I would be interested to know what others view and ideas are on this. .
The barometer measures air pressure and the new one on the APM 2 pretty accurately.
I believe that you have hit a on significant problem for Multicopters.
Finding an unaffected static air location is always hard even in conventional airplanes where it is also often used for determining air speed.
In Multicopters even without a dome, static air is really hard to come by and even if you did have an ability to position the sensor, it would be hard to know where to put it.
One effect that I have noticed is that if you have gusty updrafts or down drafts it also affects perceived altitude (ostensibly because of the relative air pressure difference) and the copter travels up or down accordingly potentially even to the ground.
Reality is that for tiny little very close to the ground vehicles like multicopters, an air pressure sensing device is a very inadequate means of gauging altitude especially on a moment to moment basis.
We have sonar but that only really works to about 12 feet or so AGL and it is essentially limited by physics in air from being effective at much greater distances.
What we need is a cheap and very small RADAR or LIDAR altimeter.
This is a basic drawing to show what I was referring to about prop wash that can also affect the baro reading
Randy, in the tuning "Graph This" box which one do I tick to see the live feed for the barometer?
What draws me to such conclusions is when I see in depth discussions going on about PID tuning tor try to remove certain behavioral anomalies, but those anomalies aren't happening to many other flying the same software, then I feel there is definitely an issue on hardware that needs to be addressed rather than trying to tweak the software.
@Randy, yes I am aware the foam is for wind affect ,and this wont help with pressure anomalies.
@Robert, yes I agree that a hardware fix would be the best approach to start with.
I'm also going to fit my paragliding vaiometer to the copter to do some testing as well and with and without the cover. This variometer has an addible alert as pressure changes as well and I can record the data and down load it to a graph. I can also use this to find where there are pressure zones ad dead zones around the top bottom and sides of the copter while suspending ti on my test flight rig. Then Ill know where is the best place to have the H tube positioned.
https://www.youtube.com/watch?v=ri0n3UVbC9s
Of course i'm sure you know on the APM1 that a little piece of foam is recommended to cut down on direct wind affecting the baro although I realise this is not exactly what you're talking about. I'm not sure if we have the same recommendation for the APM2 or not..it uses a different baro and it's under the daughterboard so harder to get to.
I like your theory, I suppose it's possible to test what happens by putting your quad high up, then drop it quickly and see how the baro reacts. Repeat that test three times and you'll probably have enough evidence to show whether it's true or not.
