Bixler (1,2, or 3) setup
Hi Diydroners,
I'm looking to buy my first drone. Below I have list of parts I plan on buying for this project but as this is my first drone I would like some advise from the drone wise.
I must add in here that I studied electrical engineering and have been researching for quite some time. But, the first lesson in practical work is ask help from those with experience, so I thank you in advance for any hep you can provide
Here is the list:
Flight:Part
Bixler 2HobbyKing® Bixler® 2 EPO 1500mm w/Optional Flaps (KIT)
MotorD2826-6 2200kv Outrunner Motor
ESCTURNIGY Plush 40amp Speed Controller
BatteryZIPPY Compact 4500mAh 3S 35C Lipo Pack
Flight ServosHXT900 9g / 1.6kg / .12sec Micro Servo
Rx controlOrangeRx R910 Spektrum DSM2 9Ch 2.4Ghz TwinPort Rx
Battery ConnectorsNylon XT60 Connectors Male/Female (5 pairs) GENUINE
4mm Bullet Connectors4mm RCPROPLUS Supra X Gold Bullet Connectors (10 pairs)
Wing strengtheningCarbon Fiber Square Tube 750x6mm (AU Warehouse)
Flight Electronics #1:
Flight ControllerMultiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560) V2.0
FC GPSNEO-6M GPS Module
FC mounting boxTurnigy Mounting Box for MultiWii AIO Flight Controllers
FC anti-vibrationGeneral Purpose Anti-Vibration Rubber w/M3 x 11mm Screw and M3 Nylock Nut – 4pcs/set
FC power controllerTURNIGY 3A UBEC w/ Noise Reduction
FC voltage protectorTURNIGY Voltage Protector
MultiWii to reciever10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
3DR TelemetryFPV 433Mhz Radio Telemetry Kit 100mW V1.1
Volt meterIn-Line Voltage and Amperage Meter
Servo lead extensions60CM Servo Lead Extention (JR) 26AWG (10pcs/bag)
Flight Electronics #2:
Flight ControllerHKPilot Mega 2.7 Flight Controller USB/GYRO/ACC/MAG/BARO (AU Warehouse)
TelemetryHKPilot Transceiver Telemetry Radio Set V2 (433Mhz)
FC Power moduleHKPilot Power Module with T-Connectors and 6 Pin 150mm Cable
Expensive FPV Gear:
Main CameraMobius ActionCam a 1080p HD Video Camera Set With Live Video Out
FPV TxImmersionRC 5.8Ghz Audio/Video Transmitter - FatShark compatible (600mw)
OSDMinim OSD v1.1
Rx/Tx antenna5.8 GHz Circular Polarized Antenna RP-SMA (Transmitter and Receiver)
Antenna extensionSMA Male - SMA Female 180mm Aerial Extension Fatshark/ImmersionRC Compatible
FPV camera servosHXT500 6.2g / 0.6kg / .08sec Micro Servo
FPV camera gimbalFPV Fiberglass Pan-Tilt Camera Mount L-Size
Cheap FPV Gear
Main Camera1/3-inch SONY CCD Video Camera (PAL)
FPV Tx and RxBoscam 5.8Ghz 200mw FPV Wireless AV Tx & Rx Set
Laptop Ground Station:
Lipo chargerIMAX B6 50W 5A Charger/Discharger 1-6 Cells (GENUINE)
FPV RxImmersionRC UNO5800v2 5.8GHz A/V Receiver w/GS-Link - Dual Output
FPV BatteryZIPPY Compact 2200mAh 3S 25C Lipo Pack
Tx controllerTurnigy 9XR Transmitter Mode 2 (No Module)
Tx BatteryTurnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack
Tx ModuleOrangeRX DSMX/DSM2 2.4Ghz Transmitter Module (JR/Turnigy compatible)
Telemetry antennaRMILEC 433MHz SRC771 1/2 Wave Length UHF Antenna FPV
telemetry caseTelemetry Radio Cases for Ground and Air Modules
AV in to USBUSB Video Capture Device - Basic Edition (AV to Computer)
Goggle Ground Station
Goggle power adaptorXT60 - JST Male In-line Power Adapter
GogglesQuanum DIY FPV Goggle Set with Monitor (KIT)
As you can see there are a few different configurations here. The reason for this was to get an idea of different price ranges and adaptibilities of equipment. I prefer flight electronics #2, the expensive FPV gear (obviously), and the laptop ground station. This being said, I cant exactly say which one is best.
Any comments are appreciated.
Thanks.
PS. a .ods file of the above list is attached and all equipment is avaliable from Hobbyking.
Bixler FPV setup.ods
