Posted by desmond13 on October 23, 2014 at 12:55am
Hi to everyone,
I am a PhD student and my lab has an IRIS quadcopter. I was wondering if is it possible to fly indoor with it or not? Even if it is needed some kind of hack.
Thanks a lot,
Fab.
You can use a precise (+-2cm) Indoor "GPS": http://marvelmind.com/.
Here the a couple of demos:
94087
Not sure what your need is as far a flying the IRIS indoors but I wanted to share this in case you havn't seen it already.
Amazing project!
http://http://diydrones.com/profiles/blogs/project-tango-3d-mapping...
And here is Chris Anderson and Brandon Hurd speaking a bit about it at ARM TechCon http://youtu.be/EwYTgzfQ-A8?t=20m40s
Thanks for the reply. The first link , on the bottom.. That guy is from my department in Naples, Italy :) I knew that project. Thanks anyway.
The second video is cool :)
You'll need to change the Arming Check (ARMING_CHECK) param within Mission Planner to ignore GPS lock before arming the motors for flight.
http://copter.ardupilot.com/wiki/prearm_safety_check/
That is what I did to be able to use the IRIS indoor:
