Hello,
The leds are flashing A+C then B then repeat.  Which is similar to This post but his fix, remove the jumpers, isn't my problem as I have no jumpers connected.
After 45+ seconds the blue LED on the GPS does go solid but the A+C then B leds just blink back and forth the longest i left it connected was 5-6 minutes.  I tried the reset after power on to no avail as well.
Thanks in advance for any help!
-Rob
    Did you load flight code (ArduCopter or ArduPlane)? Nothing will happen until you do.
