X and Y axis makes sense to have it centered between the arms, does this also apply to the Z axis? If it does, what points would you measure from? Keep in mind this is not for performance or acrobatics just extremely stable flights.
See this thread for more information in 2012.
Active stabilization doesn't require lowered COG. The feed-back loop takes care of it for you. I see that most quadcopters have a lowered COG. That just adds a moment arm that the feed-back loop has to spend more energy countering.
I am just finishing mine and I took care to make sure the COG in Z axis is balanced around the rotor center line.
