Connectors for ArduPilot and other Boards
I have had a number of times when I have needed to make a custom cable for my set-up.
The problem was sorting out the Connectors.
It took some time and research before I got it right Size Wise.
So in the spirit of sharing here are some details on the main (2) sizes 1mm & 1.25mm Pitch.
Enjoy
1mm Pitch Spacing
CONNECTOR HOUSING
Farnell Part No - 1679108 - 1679116, 1830829 - 1830835
    Item Code
    SHR-02V-S-B
        to
    SHR-15V-S-B
    Change the numerals before the V for the number of connections    2-15
CRIMP TERMINAL, SH SERIES
Farnell Part No 1679122     JST (JAPAN SOLDERLESS TERMINALS)
Wire with crimp attached - M40-9010099
Description: LEAD, CRIMP/FREE END, 32AWG, 150MM Cable Length
Farnell Part No 8729239
Wire with crimp attached - M40-9070099
Description: LEAD, CRIMP BOTH ENDS, 32AWG, 300MM
Farnell Part No 1972271
1.25mm Pitch Spacing
 1.25mm PicoBlade Wire-to-Board Crimp Receptacle Housings
Wire with crimp attached - 1125273 - 1125276
1.25mm PicoBlade receptacle
VARIOUS NUMBERS  GO TO - http://uk.farnell.com/jsp/search/browse.jsp?N=2031+204643&Ntk=gensearch&Ntt=1.25mm+PicoBlade+receptacle&Ntx=mode+matchallpartial
CRIMP TERMINALS - MOLEX - 50125-8000 - TERMINAL, MALE, 1.25MM, AWG26-28
Farnell Part No - 1756745
Wed 14th August UPDATE
Have now found a Acceptable Price (£44.00) Crimping tool that will do both sizes.
It is Engineer INC. Japan. Model PA-09 - http://www.engineer.jp/en/products/pa09e.html
Other Crimping Tools to do a Wide Range Cost £100.00 +
You can buy it at -
http://www.ebay.co.uk/itm/universal-mini-micro-crimping-tool-molex-kk-zh-jst-xh-sl-amp-crimp-pliers-PA-09-/251268499824?pt=UK_Computing_NetworkingTools_Accessories_SM&hash=item3a80c50970
I have tried it on both sizes and it works great but I think it's time I had my eyes tested again.
The 1mm pitch really needs a magnifying glass.
FARNELL BASIC P & P (2-3 Days I usually find) FREE
Usual disclaimers apply I just find they give exceptional service
  • Thanks!
  • If anyone with wiki access is reading this, I think this is good info for on the wiki.
    Gerrit Jan
  • Nice!
    Would be great to find part numbers for these parts at DigiKey, Mouser and Newark as well.
  • thanks so much for this!
  • Thanks!
    Almost in time for another member's question HERE. (I linked his question to this post)
    -=Doug
  • Amazingly useful work!
