Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Better if you can share
a log, easier to help
I'm using copter v3.3.3 on a tricopter as shown in the diagram below. My yaw servo is plugged into a Pixhawk main out 7.
I don't seem to have any control of the yaw servo when the safety switch is armed or when the tricopter is armed. Should I expect the transmitter yaw stick to control this servo on the tail motor? Are there any settings I may have missed to select a tricopter other than when downloading the firmware?
Thank you...
as Hubertus mentioned only FC controls that servos, try raising throttle to about 20% aand you'll be able to.
also, there are a few settings to set for proper yaw control on a tricopter, otherwise it will be "laggy".
ATC_RAT_YAW_FILT = 20
ATC_SLEW_YAW = 18000
ATC_Y_MAX = 100000
these are for ac3.4, so to find them in ac3.3 just omit the "ATC" part.
if you encounter "wagging tail" try lowering yaw_stab and yaw PIDs. D needs to be 0 for the "manual like" yaw control, otherwise AC controls yaw too much and it gets slow...
Ok, thank you for the suggestions guys. I forgot to mention that I have a 5v regulator plugged into Pixhawk main out 8 and the motors 1, 2, and 4 are opto ESCs that all work fine. The yaw servo seems to be energized but I wasn't sure about the APM operation. Based upon your suggestions, it may be the laggy feel I am experiencing.
This is my first tricopter, which is also a tilt wing, called a CL-84 from Hobby King. I flew it fine using SimonK ESCs and the stock controller allowed for yaw stick to move the yaw servo. While I wait for Tridge to make some special tilt rotor code for the CL-84 transition servo, I thought it would be cool to try Arducopter v3.3.3 and have it hover in place like a real autonomous vehicle. We'll see what happens...
You guys were correct. I re-tested and I do have yaw control, but it is real sluggish. I found the RATE_YAW_FILT parameter and changed it from 5 to 20. However, the other two parameters elude me. Could the names be different in v3.3.3?
RAT_YAW_FILT = 20
SLEW_YAW = 18000
Y_MAX = 100000
try searching for "slew" and something related to acceleration over Y axes.
setting those will give you the "manual" like yaw control.
also, it helps to properly set servo endpoints to something like 1100-1900, defaults are really minimal.
do not forget your servo midpoint, i find that setting it slightly off center to counter natural yaw helps, but since it is a "plane" not sure how it will affect the fixed wing mode.
That's much better. I found the params in v3.3.3 as follows and set them to your values. I have yaw control now. Thanks for the tips!
RATE_YAW_FILT = 20
ATC_ACCEL_Y_MAX = 100000
My CL-84 VTOL is hovering quite nicely in some wind now after adjusting some PIDs. This was just a test while I wait for Tridge to release some new Arduplane code for the CL-84 tiltwing. I also updated my Tarot 680 Pro hexacopter from Copter v3.1.4 to v3.3.3 and after re-calibrating the ACCs and GPS, it flies perfectly!
CL84 with APM Copter Test 2 from Gregory Covey on Vimeo.
Greg,
you can´t control the servo with the yaw stick, it is controlled by the FC when flying.
1
2
3
4
5
of 449 Next
