Hi All, I don't know if it's something already experimented but I was wondering if it could be possible to implement some sort of differential GPS mechanism.
Basically if we could have two identical GPS, one airborne and the other positioned on a precisely know position and attached to the base station we could measure position error of the base station and transmit the error vector to the drone to be added to the on-board calculated position such enhancing accuracy.
Probably some technicality will have to be managed, for example we should lock the number of satellite to be considered on both units unless the two measure will not be comparable.
Does anyone has any experience about this? Is it something that makes sense?
Thank You very much,
enrico
Tags: GPS, accuracy, differential, error, positioning, vector
Permalink Reply by Jake Stew on August 18, 2012 at 11:53pm It's been talked about recently. You might search for "AGPS" to find the threads.
It's certainly a good idea, but I don't think anyone's working on it at the moment.
Permalink Reply by Enrico Bazan on August 20, 2012 at 12:23pm Hi Jake,
I tought that A-GPS meant Assited GPS, i.e. GPS + GPRS/UMTS.
I'll look at the thread to find out if I can giva a small contribution.
Thanks,
enrico
Permalink Reply by Jake Stew on August 20, 2012 at 1:24pm I realized it might be pretty hard to find the thread even though it's pretty recent. There's some discussion on various potential high accuracy GPS methods here. It's the best and most recent thread on the topic AFAIK. Don't be afraid to bump the thread.
High Accuracy RTK Positions with the LEA-6 using RTCM via NTRIP
http://diydrones.com/forum/topics/high-accuracy-rtk-positions-with-...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
134 members
24 members
51 members
1298 members
Powered by
