DJI Matrice 100 with X3 Camera, Guidance and Manifold Computer - $4500
I have for sale a DJI Matrice 100 equipped with the DJI Guidance System, X3 4K camera/gimbal and Manifold Computer. This drone is in excellent condition and I'm selling it because I'm upgrading to to a larger drone with the newer Z3 zoom camera. This drone is DJI's developer platform. The system includes the M100, Radio, Single Battery, Guidance System, and Manifold Computer with DJI's SDK pre loaded.
This drone is in like new condition and ready to ship or pick up in Fort Lauderdale, FL. I will only ship to a US Address. The pictures below are of the actual drone as well as the DJI Website.
Details from the DJI Website:
The DJI Matrice 100 is a fully customizable and programmable flight platform that lets you to turn your ideas and dreams into reality. Equipped with DJI’s easy-to-fly technology and optimized for easy programming through the DJI SDK, the Matrice 100 is ready to carry any sensors, devices that you want to put into the sky.
M100 with GUIDANCE
Complete Flight Platform - Start flying quickly, and enjoy stable, reliable flight. Your Matrice 100 platform has all of DJI’s easy-to-fly technology built in, and includes the flight controller, propulsion system, GPS, DJI Lightbridge, a dedicated remote controller, and a rechargeable battery. This system automatically manages the most complex tasks required for flight, so you can focus on your work.
Fully Programmable - Customize and tailor your flight platform by using the DJI SDK. Develop a system for any use, and revolutionize industries by applying your knowledge and skills to cutting-edge flight technology. Teach your Matrice 100 how to behave and what to do. Program customized commands, tell it how and where to fly, and gather information from the entire system in real time.
Long, Extendable Flight Time - A lightweight frame and efficient motors give you up to 40 minutes* of flight time. For greater flexibility when adding additional payload, an optional second battery can be mounted into a dedicated power slot. *Flight times vary based on payload and flight conditions, and the maximum 40 minute flight time tested when hovering with dual TB48D batteries and no additional payload.
High-Precision Vision Positioning - Even without GPS, achieve hovering that is accurate to within centimeters. Even when flying at high speeds, high-precision stereo algorithms provide positioning information over nearly any terrain. Guidance’s vision positioning system is effective at altitudes of up to 65 feet (20 meters). Obstacle Sensing in Every Direction - Guidance continuously scans the nearby environment and detects obstacles in real time. When used with a DJI flight controller, it can tell your flight system to automatically avoid collision, even at high speeds.
Guidance is a revolutionary visual sensing system. With a powerful processing core, integrated visual cameras, ultrasonic sensors, and the most advanced computer vision algorithms in the world, Guidance protects your platform and gives you a new level of safety and confidence in flight. Guidance includes five sensor modules and one central processor.
MANIFOLD
Powerful Processing. Limitless Possibilities.
The Manifold is a high-performance embedded computer specially designed for the DJI Onboard SDK. It enables developers to transform aerial platforms into truly intelligent flying robots that can perform complex computing tasks and advanced image processing literally on the fly.
Powerful Computing on the Fly
With the NVIDIA Tegra K1's 4-Plus-1 Quad-core ARM Cortex-A15 Processor, the NVIDIA Kepler GPU that contains 192 CUDA cores in each SMX, and clock speeds of up to 2.2 GHz, the Manifold allows you to take-off with the world's most advanced mobile processors. The GPU cores provide powerful image processing abilities, efficient parallel computing, and a blazing fast throughput of 326 GFLOPS. Now you can design more intelligent applications that unlock the full potential of your aerial platforms in whole new ways.
Advanced Image Processing in the Sky
The Manifold packs the processing power of a PC graphics card and supports DirectX 11 and OpenGL 4.4, enabling your aerial platform to process complex images in real time. The Manifold also supports NVIDIA CUDA, which can be used to develop the most advanced GPU-accelerated applications and boost the performance of a program. It can be deployed for use in artificial intelligence applications such as computer vision and deep learning. This means your aerial platforms will not only be able to sense the surrounding environment, but also identify objects and respond almost instantly.
Convenient Development Environment
Designed for developers, the Manifold's built-in Ubuntu operating system supports Linux, CUDA, OpenCV, and ROS. It is ideal for research and development of professional applications. The Manifold can natively run the DJI Onboard SDK, access flight data and perform intelligent control and data analysis. With CUDA, the Manifold can be used to accelerate your applications to achieve unprecedented levels of performance.
Low Power Consumption
The Manifold is optimized for power efficiency with a peak power consumption of approximately 15 W, or one fourth of that of a typical laptop. The Manifold's Tegra K1 CPU uses four A15 cores for heavy computing tasks, and a single battery-saver core when performing simple calculations. The number of active cores can be dynamically adjusted to decrease power consumption, and the extra core is automatically activated when needed.
Versatile Compatibility
Limited space on aerial platforms is no longer a limit to developing powerful applications. With a size of only 11 cm x 11 cm x 2.6 cm, a weight of less than 200 g, and built-in customized ports, the Manifold is optimized for DJI developer platforms. It can be easily mounted to the expansion bay of the Matrice 100 and Matrice 600, and is also compatible with the A3 and N3 flight controller.
Comprehensive Connectivity
Equipped with USB, Ethernet, Mini-PCIe, HDMI, UART, SPI, and I2C ports, the Manifold allows you to connect to a wide array of sensors, monitors and other peripheral devices. The Manifold also provides customized ports to connect to the Matrice 100 and Matrice 600, so the images captured by the camera mounted to the platform can be processed. This opens up more possibilities for developers to create extraordinary applications.
If interested, please contact me via DIYDrones or email at billrockus@gmail.com
