Can anyone help me with the specific dronekit-python code to read and write the SR0_EXTRA1 parameter (and its friends) on APM3.3? I assume they need to be written as direct Mavlink commands.
I am having trouble holding them stable when set by Mission Planner, so want to set them direct from Raspberry Pi (on ground) via telemetry to APM at beginning of flight.
Gibbo
There seem to be some stability issues between MP and the APM settings - and I can't get SR0_EXTRA1 in particular to stay put. I sense there may be a coding issue, and have posted question / issue on github/diydrones.
I would rather not write it direct, but it looks possible, and I would like as a back up plan so I can force them as needed.
The image below shows where you need to set them in MPIf you want to write your own app for the RPi look at dronekit.io as a simple way to enable sending request data stream messages or set params (you could use MAVProxy in the RPi or even APM Planner 2.0* also)
*(You will need a minimum resolution of 1024x600 for AP2)
Thanks for the input. Unfortunately that approach is not proving stable and I sense may have a bug for APM3.3 (that Attitude should write to EXTRA1 but seems to write to EXTRA2, while EXTRA1 always gets written back to default on connection). See details here: https://github.com/diydrones/MissionPlanner/issues/1004.
I am using dronekit-python (from dronekit.io) on RPi but can't find the specifc code (or pieces of it) to request these specific stream rates, or set them - either at python level (using the dronkit-python Mavlink call I expect) or RPi command prompt level (via Mavproxy).
I have good control through Mission Planner now - knowing to use F5 to commit changes after making them. But they still reset to defaults on a new USB / telemetry connection to Mission Planner - and I am trying to work out whether that reset is triggered by Mission Planner or by the APM itself on seeing a new connection.
