  • Yep, I found a nice little enclosure at Radio Shack/Circuit City.  It's about twice as big as it needed to be, but that's fine. I mounted the board by drilling a hole in the side for the antenna coupling.  There is a nut and washer included to clamp it down.  I attached a USB cable which is basically permanent.  I glued it into the case, so that it doesn't strain the Xbee socket.  The wire exits a second hole.  So now I have a little black box with an antenna sticking out one end, and a USB connector coming out the other side.
    I would definitely buy one of those... no 3d printer :-(
  • Cool enclosure. I don't suppose you have a spare? :)
  • I placed mine in this thing, but it requires a 3D printer. :)
