Tags:
Permalink Reply by Jose Luis Cortes on February 4, 2011 at 10:00am Hello Ying, you need good controller-motor-propeller efficiency to keep a plane in flight with 200w and 7kg, I think this motor is big, it get maximum efficiency with more than 15A.
Permalink Reply by Calvin Lee on February 6, 2011 at 9:51pm Yes, I reckon that I need good motor and propeller efficiency but I am could not find materials on motor sizing for this application. Thus, I am hoping to gather some good resources or experience from fellow forum-ers..
For the propeller sizing, we purchased a good number of them of varying diameters and pitches to select the better one. Controller wise, I didn't take note of the efficiency side of it. Perhaps we should do that now too..
We were aware that the maximum efficiency is above 15A. We chose this as it is the 50 series motors which reflects maximum efficiency having lower range limit (15A in comparison to higher ones in 40s/30s/20s series). There are 50s series motors with maximum efficiency lower range limit of 8A but that is unavailable when we were purchasing.
Permalink Reply by Jose Luis Cortes on February 4, 2011 at 11:00am
Permalink Reply by Calvin Lee on February 6, 2011 at 9:58pm The 200W would be continuous output. The peak output is 600W.
The design comes with an inherent lipo battery attachment to cater to the purging of the fuel cell to remove the generated water. We are in view of using another lipo battery for the same purpose of climbing.
However, we need to up the thrust produced by increasing the efficiency of the controller-motor-propeller combination and my main suspect is that the motor is not exactly compatible/efficient...
Permalink Reply by bGatti on February 4, 2011 at 10:44am motors are rated at RPM per Volt. as you have High voltage, you'll generally want a slower motor; I'd also consider a geared motor to help reduce speed and increase efficiency.
Here is an interesting option:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
it's a dual motor, but your problem is still high voltage - so you may need to rewind the motors.
Permalink Reply by Calvin Lee on February 6, 2011 at 10:09pm Hi! May I understand the relationship of high voltage with slower motor..?
meanwhile, i will check out geared motors and hopefully thats increase my efficiency..!
200W / 7kg is 28W a kilo, low powered efficient gliders can fly on as little as 60W per kilo, 28's going to be pushing it a bit. You'll need a highest quality competition motor with 6:1 (or higher) gearbox and massive propellor to get any results. Kontronik and Hacker brands come to mind.
Something like the Kira 650-11 with 6.7:1 gearbox might produce some thrust at that wattage with a very large prop (Kontronik Kira 650-11)
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.74 members
685 members
133 members
51 members
314 members
Powered by
