I'm doing missions the standard way (upload waypoints, switch to auto and hit the throttle to start them). Is there a way to avoid the use of the throttle? Just upload the mission and switch to auto?
thanks a lot for any pointers.
dc//
dc//
You can do that with a tablet (or PC) with telemetry. Insert Take-off and RTL at beginning and end of the programmed flight. Then, use your GCS to Arm and start the Auto flight. R/C should be On. After TakeOff, it is prudent to move Throttle lever to middle position if you need to take control manually.
Marc
