I'm reasonably new to quadcopters although have been learning a lot over recent months. I've tried a couple of takeoffs with no success and after flipping last time out, decided I had something fundamental wrong.
My problem is with the Gyros. I'm running APM Planner 1.1.48 and Arducopter V2.5.5 with an APM 1 board. If I look at the raw sensor output, my gyros are all over the place. So I've been trying to remove potential issues bit by bit and am now at the point where I have just the APM out of the quadcopter witting on the bench. I connect my usb and go into APM planner.
I go through "terminal" and erase; reset; then into config and set mode to "+"; put in my declination; do a "level" then go to Raw Sensor display and deselect the Accelerometers so just the gyros are displaying. They are up and down like crazy!
I'm at a point where I have no idea what's wrong. Any and all help appreciated.
Thanks.
First, you've got an ancient Mission Planner. Please upgrade to the latest version. Second, if that doesn't fix it, you've got a hardware issue. Did you solder the board together yourself?
