Hi team,
I have finally decided to get off my backside and start the long and slippery path to despair and bankruptcy, an Intel Atom powered autopilot. Why you ask....for a giggle and to see if it will ever get off the ground and the simple fact it gets cold in Eingglund so 1.6Ghz of silicon heating will keep the insides warm!
The project so far consists of an PicoItx motherboard 1.6 Ghz Atom with 2 gig of ram and an 8gig CF hard drive running Windoz Embedded 2009 (cutdown XP). The board has 4 USB ports, 2 Serial ports and some other goodies running at 5V with just a heatsink for cooling (not in photo).
As it stands the board / ua does the following:
Webcam steaming 640x480 Divx to the GCS via WiFi
GPS streaming to the GCS
3 Axis accel streaming x,y,z to GCS (will be replacing with IMU)
16 servo USB board
GCS so far:
Displays streaming video
Displays GPS data with graphical dials etc
Real time moving maps from gps data – Can select Google maps,Google terrain, Google sat, Bing maps, Yahoo maps etc etc maps get cached locally in Database so works offline.
Joystick control sends servo commands to UA and moves them
Very much a work in progress, will probably never fly, but is keeping the grey matter from rotting away.
Cheers
Justin
That's some pretty hefty hardware you're putting up in the air! Thought about doing any onboard optical flow control or the like?
Hey Kyle,
Yeah I have a few ideas in the pipeline, instead of being smart and designing the right hardware i thought i may as well throw some Ghz at the problem instead :) - after the video processing there is still alot of FLOPS going begging to play with and add some smarts....
This is cool, but what is the flight control SW you use ? ,IMU sensors and stuff ? how do you manage all that together ? , it is 2011 now :)
I'm automated a great deal around my house with Arduino trying to get used to it (my curtain controller stepper motor broke this morning :() and in doing so have bought far too many Pro Minis. So I've designed a PCI card with an ATMega 2560 on it and all the leads on the backplate. I've got 3 UARTs spare, 40 IOs, 12 PWM, 16 analogue ins and a direct FTDI into the computer.
It's not particularly hard to take the 2560 reference design and make it fit a PCI board although the PCI custom part is slightly annoying. I'm waiting on its arrival to get my server hooked up and take over everything in the house :D
Also you may want to consider doing sensor boards instead of just sensors. That way calibration is done by the board and the output is exactly as you wish so your Atom only has to interpret lightening its load.
All the code is custom written in C# and held together with sticky tape. On the hardware side its the Atom as the main processor with an Arduimu talking to some Netduino Minis and lots of wires.....
