Hi folks!
My plane flies well in the same direction of the wind and so fast (65km/h ground speed and 43 km/h air speed). But, the problem is against the wind! It start to make snakes from waypoint to waypoint...and flies very slow...(30km/h ground speed and 65km/h air speed). I have upgrade My GPS mediatek to version 1.6 but I think that it is not the entire issue.
I have set 18m/s Airspeed cruise and 55% Throttle cruise in the parameters screen.
I don t know if I´m doing something wrong..
I think that when the plane flies in the wind direction it goes well because ground speed is high, so, I must keep high or constante ground speed ! right?
HI Franco,
I would like to know if you were able to fix your speed,
I have this question:
HI, I am using the APM 2.6 on Maja too.
I have some questions regarding the plane speed and the wind speed
I have the plane without an airspeed:
If the plane is defined to fly from a waypoint to another at speed 45km/h and if the wind speed is at 30km/h, at what speed the plane will fly?
A- if the wind direction is with the same direction of the plane, will the plane flies at the speed of 75km/h
B- if the wind direction is against the plane direction, will the plane flies at 15km/h?
C- will the plane adjust the speed to keep it at around 45km/h?
D- if yes, how it will do it? Based on GPS and Compass? if no airspeed is installed
E- if no. It means it needs an airspeed sensor to adjust the plane speed, isn't it?
Your reply is very important for us.
You selected APM Mission Planner as your topic, so I think people are confused by what you're using. Are you flying the latest ArduPlane software?
Please any suggestions for this issue???
