    Anyone get this to work?
    well thats the pits then. I guess I am stillnni the dark with regard to Telemetry. I'll have to pickup a Xbee telemetry kit from DIYDrones.. when I get some more hobby funds:P
    I''ve rendered the units I had, unusable forever.
  • @grips, you're just writing a register.  The module will not be able to transmit at a frequency that it's not built for.  I tried it in the higher frequency range and it doesn't work. (No communications)
    To use my APC modems reliably I have to reduce telemetry rates... Usually this isn't a problem for me, as when I'm tuning, telemetry isn't my concern. After tuning I jack them back up and all is kosher. I believe any issue may stem from the APC's shared buffer... But I've been known to be wrong...
  • 100KM
    There's no hack that I know of.
    uploading firmware with wireless link doesn't work with any wireless link.
    Changing pid's values works with me, I get an error message sometimes, but the value usually IS changed.
    If you want more help, pls be more specific about what exactly doesn't work.
    FYI: These are not legal to use in Canada for anyone else searching for info.
