I have noticed in the forum a number of people advising the connection of ground (negative power) of all their ESCs to the APM.  In some cases some people are also connecting multiple 5 volt lines to the APM in the hope of providing redundancy of the 5 volt line.   In my opinion  both these practices can lead to intermittant issues that could cause your copter to occassionly behave erratically, and at worse damage your APM (as connecting multiple ESC grounds to the APM can create ground loops). Ground loops will create a noisy and unstable ground for the APM, which is the last thing you want with sensitive gyros and accels.  The random issues that ground loops/bad power can lead people to incorrectly assume that there is something buggy with the software, causing unnecessary work for the developers and testers.
Ideally a seperate, single BEC (5 volt regulator) should be used to power the APM as the 5 volt line from an ESC that is also powering a motor will get very hot, causing the 5 volt line to become noisy and possibly brown-out/shut-down in flight.  The BEC should not get so hot that it is uncomfortable for you to keep your finger on it for more than a couple of minutes with APM+GPS+Xbee etc connected.  If so, a BEC with a larger heatsink  or a switch-mode BEC should be used. In addition using a seperate BEC also ensures that the APM does not share a noisy ground return of an ESC.
I think a lot of the intermittant and unexplainable issues people have had can be resolved by ensuring the power supply and powering wiring topology is sound to begin with.
Does anyone know who contact about having documentation updated to reflect the above?
Tags: 5, BEC, ESC, crash, ground, lock, loops, power, redundancy, supply, More…up, volt
Even on Earth it is important to have a singular ground because ground has resistance and lightning strikes occur.
I use fixed wing for my airframe, but having a good power plant is also the same for this type of Airframe... I will use a Turnigy 3s 1300mAh and a BEC to power the Video Tx for FPV & the 5 volts for APM. The motor will use seperate batteries & ESC(not using BEC).  But regarding grounds... I'm confused... since the Motor ESC is controlled by the channel 3(throttle)... well, we will and up with a single ground... no?  But disconnecting the 5V line from that ESC(Motor) might be a good idea.
Thank you Michael for this post, I was thinking about a good power plant lately.
I agree with you, issues regarding power plant should be "filtered" in order to give some "slack" to the developers and testers.
cheers, E
Good discussion.  I have access to modify the Wiki and I can help you get it "published" there if we can come up with a good document.
I'm fairly well off in my case as I have a trad.heli. with a single ESC, and that ESC is opto-isolated, and the motor battery is completely separate from the radio system battery.  But, my radio power system is somewhat confusing...  I have an L7805 5V regulator powering my receiver and APM.  Then I have a 6V switching BEC powering the servo rail on the APM for my three swash servos. And then my tail servo is direct 11.1V to the 3S battery.  But all of those share a common ground back to the battery. In particular, the ground for the 3S servo actually goes THROUGH the APM and the APM ground.  I had to do that, because when I had the ground for that servo going directly to the battery, I had a noise problem.
It's worth discussing in this article that you want to try to keep grounds seperate, but they must be connected in some way.  A signal source operating at 5V, and a signal receiver operating at 5V will not communicate if their grounds aren't connected.
Yes, that is correct.  I did the "Jason power hack".
I did not sever the ground track however, and I wonder if I should.  I was using a power analyser to measure the current the APM is using, and I noticed that when I load the servos, the current on the APM appears to spike, which should be impossible.  I believe this is simply an artifact of the system...  The power analyser has positive and negative for both load and supply.  Basically you unplug the power supply, and insert the analyser between the supply and the load.  I think since the ground servo rail is still connected, some of the electrons returning through the ground go through the APM ground wire, not just the servo BEC ground wire.  This tricks the analyser into reporting that as power going through the system, when in fact it's not really.
It causes a problem for the power analyser, but I don't know if it causes any real problem with the system.
Hang on, two seperate issues here.
The 3 cyclic servos are plugged into (all three wires) into the output servo rail of APM.  The power trace of that rail is independent.  Powered by my BEC at 6V.  There is a ground and power wire going from that rail, to the BEC, then to the battery.
Then on the input servo rail, is plugged in only the reciever via all the channel wires.  It also has power and ground going to the L7805, and then back to the battery, both wires.  The power rail is connected to the APM, as is the ground.  That's how the APM board is connected.
I think all tha this is happening, is that since the ground rails are connected, any electrons coming from the BEC, through the servos, and then back to the ground servo rail, half of them go back on the BEC ground, and half of them go through the L7805 ground.  You know, path of least resistance is to split and go through both ground wires.
I'm not sure if this is a problem or not.  I'm also not sure if splitting the ground rail would help.  Maybe it will?  I guess I can do that.  Don't see why not.  Then they'll be completely seperate all the way back to the battery connector.
This all reminds me of a headache-inducing conversation I had with an elec-eng neighbor who was telling me that if I ever try to hook my generator up to my electrical panel (yes, I know about the rest of the safety precautions) that I should... oh geez, how did this go... I should not hook up the ground wire because it would create a ground loop and the chassis of all connected equipment would be energized... something like that.
I have tried using copteret without ground(-) from esc's to the apm completely unaware of this, because I switched to separate bec right into the pdb. That led to a crash for me. The copter got a strange behavior. When it was below 5 degrees outside, I do not get the copter armed, the engines just beep rapidly.
The esc's are Jdrone 30amp, yes you right, there is some component inside the esc,s that are not working in low temp, but that issue give a strange behavior to the copter flying indoor.
On a large camera mount, do you think it would be better to get the power for the mount servos from a seperate BEC and just get the signal from the APM. Instead of getting power and signal from the APM???
Very Important!!! I've been building power supplies for years and noise is always an issue- the more sensitive the circuit you're driving, the harder you have to work to clean it up to avoid glitches.  Circuitry as sensitive as the APM can only benefit from clean power.  So what about some of the standard DC filter systems?  Toroidal chokes/ Caps/ Tuned low/high pass filters?  Another solution is a small 2s Li-po battery to power all the electronics directly through the APM with a separate big battery for the esc/motors.  A separate small battery has the advantage of acting as a broadband filter by just absorbing and overpowering most noise.  Also- any wire can act as an unwanted antenna for noise so long as it is the correct (wrong) length.  Lots of different length wires around lots of noise sources means more noise in your circuitry.
Redundant 5v supplies should definitely be avoided- they usually don't play nice operated in parallel.  Crosstalk between input stages in separate regulators can cause all sorts of ugly noise.  ALL grounds do need to be tied together to make sure all devices share the same ground voltage, but any additional grounds will only add noise.   I would suggest removing the +5 pin from the esc/bec connectors and just connect the ground and sig-out to the esc's which would  provide common ground to the drive system without creating any loops or introducing additional noise.
I found this device, i'm not sure if I should use it.
The following diagram does'nt use a second batterie for the electronics but it shows your point regarding the removal of the +5V pin from the esc/bec connectors.  And keep the ground.
I stoled the diag from the link below ;)
But please note, some ESC's need the power connected!  My 100 amp ESC is opto-isolated.  The board has two sides.  One is powered by the motor battery, the other is powered by the reciever.  So I need that power wire connected to the reciever.
I know this is not the case with most quads.  I just wanted to point it out in case any heli guys come across this.
