inverted v-tail elerudder config
Hello everyone
I have searched hi and low trying to find out how to set up the inverted v-tail.
Pitch and yaw work well for the standard v-tail. But for the inverted v-tail if I get pitch to work I am unable to get yaw to work in the proper direction.
The air frame I am trying to config is the RMRC anaconda.
  • Admin
    @Gregory,
    I just completed setting up my Anaconda in the Manual mode.
    Here is how I have it configured:
    I setup the joystick throws according to the Wiki:
    Ch 1: Roll left=low…Right=high
    Ch 2: Pitch forward=low…Pitch back=high
    Ch 3: Throttle down(off)=low…Throttle up=high
    Ch 4: Yaw left=low…Yaw right=high
    RCMAP_PITCH, 2 Left V-Tail servo
    RCMAP_ROLL, 1
    RCMAP_THROTTLE, 3
    RCMAP_YAW, 4 Right V-Tail servo
    VTAIL_OUTPUT, 2
    Typicalaimster had his VTAIL_OUTPUT set to 3, but that did not work for me. I would have had to reverse the right and left tail servo connections to get that to work.
    I still have to check the FBWA servo movements which might require me to check one of the "reverse" boxes for either PITCH, YAW, or ROLL.
    TCIII AVD
    • Thomas Thank you for the help with that
  • Admin
    @Gregory,
    Take a look at this parameter file for the Anaconda
    TCIII AVD
    Anaconda 111514 Typicalaimster.param
    https://storage.ning.com/topology/rest/1.0/file/get/3701927542?profile=original
