Iris+ Remote Control help
I recently purchased an Iris+ and want to change the direction of travel on the remote control.
Currently when i push the right stick forwards the Drone flies backwards ! Can anyone tell me what I need to do to change it so it is the other way around ?
Much appreciated.
Mike
  • Did it arrived from factory working like that?
    A possible solution is to reverse the elevator channel in the handset. For that, in the standard Iris+ handset, you need to press the menu key for several seconds, until it changes the screen content. Then press the minus key until you reach window 6/10. There CH2 should have "INV" in the last column. Usually, all other channels have "---" on the last column.
