Lego mindstorm based UAV with FMA co-pilot
hello guys!I am doing an UAV based on lego mindstorm. I am using FMA co-pilot as sensor. I need to communicate lego mindstorm and fma co-pilot with each other. I need to take the information from co-pilot and send it to mindstorm. then mindstorm will command the microservos. Is there anyone who has an idea. I will be gratefull for your helps.
  • can't I build my own circuit as interface between co-pilot sensor and mindstorm by measuring inputs and outputs of this devices? is it to hard to do or is it imposible? what do you think? should I give it a try?
    I don't think it can be done (and lord knows I've tried). I'd go with gyros and accelerometers instead, or just let the Mindstorms by a navigation-only autopilot, not connected to the FMA, like I did.
