Posted by pratyusha on December 21, 2014 at 9:02am
hai sir,i need mavlink communication in my project which is in C#...i have to display lat,lng,alt,pitch,yaw,roll.....but iam new to this mavlink...i downloaded mavlink master from github....but i dont know how to use that...and how to interface with my project.... can anyone please tell me how to use mavlink in C#....Thanks in advance
I used mavlink generated message header files... when iam calling the particular function like initialize(), deserialize() and i am trying to print the received types like attitude,lat etc but they are not coming.....can anyone help me to get those variables
Thank you.....By using python mavgenerator i generated header files in c#, but in that there is an error "the name 'ByteArrayUtil'does not exist in the current context".... how to solve this...which file i have to add for this...
thanks for your reply sir...but in the mission planner mavlink was used which is in c# code. Even if iam adding that mavlink.dll i didnt get the output.
yes, I am aware of >15 different projects that interface autopilot over mavlink - none of them are C# , most are C , and 3 are Python. due to little use there most lokely are bugs, and few examples on how-to do it.
Yes, was just looking into this for some other coding I wanted to do.
C# can't use the Mavlink code because it is in standard C and C# is object oriented.
The function "mavlink_parse_char()" is the starting point that will take your serial data one byte at a time until it has a complete message and then return it back to you. From there you can access the structures to determine what type of message it is and what values they hold.
I suppose you could create a c function that just does the decoding and make it a DLL library that you could then call as an external function from C#.
I have got the same problems with you..Have you solved this problem yet? If so,would you mind to tell me. Thank you.
Most of that code was rewritten for Mission Planner and uses very little of the Mavlink code even though it was based on it.
Have not gotten that far.
