Minim OSD "No Mavlink Data"
Hey,
i'm using the minim osd (3DR) firmware version extra 2.4.
But evry time it starts i get  "No Mavlink Data"
did everyone see the problem ?
iv added a connection cicuit of the minim osd and the pixhawk
and the "problem" video ;)
i hope it helps you to help me
Thanks alot
3691131755?profile=original
  • I had similar problem, but I solved it easily :
    1. power up pixhawk with main battery and OSD connected, wait until pixhawk has blue light
    2. power up analog side of OSD (gimbal, camera, video transmitter) with second battery (3S)
    3. normally now you should have signal from OSD as a layer on your screen/googles
    If you change the power up scheme in opposite direction, you get stuck with No mavlink data message. If you still see this message even after you have done the correct power up setup order, disconnect everything and wait for 5min to cool down everything. After the OSD board is cool again, start the power sequence again. This simple solution worked for me.
