Hello,
I'm trying to avoid an issue with the 5v regulator on the analog side (12v input) . It drastically decreases my UHF radio range by creating noise in the same freq (433 MHz)
From the wiki, i see this option to connect the analog/digital sides so they are both powered by the APM's 5v, which would bypass this regulator - but I really see no other information on it.
Is anyone using minimOSD 1.1 being powered by the APM only (with the above solder jumps)? Are there any special considerations? I just really don't want to blow up my minimOSD.
Thank you!
