Minimosd overlay doesn't fit on screen!
Hi!
Long time reader, first time poster.
I've had some problems getting my minimosd to fit on my screen. The osd has has the latest night ghost minimosd-extra  firmware loaded. I have also tested multiple older versions with some success, but the mavlink data doesn't update with the older ones and some data is out of frame. Is there an option for apsect ratio?
The osd is connected to my pixhawk and im supplying 5v on the video side. The only data that the osd shows is the flight mode, the other "widgets" are static.
I would guess that this is a software problem and not a problem with the osd itself, but im no expert.
Any input is appreciated!
EDIT: Found the problem, i was using an older firmware version.
  • Check PAL/NTSC
