Hello Everyone,
I have a Fixhawk with a newly built Fy690s, It is my first build so when I first flew it I thought it was weird that my copter did not react as I expected when moved around in loiter mode. It flew great and had no issues physically flying, But I had to put in the opposite control inputs in with the right pitch/roll axis. When I wanted to fly directly away from myself I had to use the roll input, And when I wanted to roll I had to use the normal pitch input. My taranis is reading the stick inputs correctly on the radio, But Mission planner is reading them the way I described above.
Any idea where I change this setting in MP?
Thanks a ton!
Maybe I'll be able to actually fly the thing the way I want when the controls react the way they should.
Nuker-
Thanks for the reply Steven, I guess I'm not sure how to make the pitch stick switch with the roll stick on the taranis, I will investigate!
Check your radio calibration settings and reverse the ones you need to. Manual and FC modes can be different. Test on ground, of course.
