2 / 2
aerodim
Hello to all of you!
kindly request your help in my problem, which after so many search and readings ....unfortunately i can't found any solution!!!
The point is that i'm very new to APM and PIXHAWK controllers and because of that, most probably, its something simple, but personally i'm totally stuck.
So i please to anyone of you for your efforts!
So, to start with, firstly to tell you my setup. I use a 450 class electrical Heli, and Pixhawk fmu controller. I use Futaba Tx T8FG super and Rx Futaba R6208SB Mission planner 1.3.49 version and Helicopter firmware 3.5.3. With main setup ...everything went well (servos moves correctly, and the Green bars in mission planner as well fine).
The controller after powering it on, gives me Green flashing light. BUT whatever i try i CAN'T (in any way) ARM my motor!!! It gives me all the time the message "Prearm: Motor interlock enabled" Which really i don't have any idea how to get rid. I try sooooo many thinks and i spent soooo much time for it ....but without Success.
Please Help me to solve it so to be possible to arm my Heli!
Any help will be MUCH appreciated.
Many Thanks in advance ....Dim
