Many apologies if this has already been asked and remedied, I wasn't able to find anything on a search..
Just got a new Surface Pro 128 the other day and have loaded MP on it.  I haven't yet connected to an APM, but wanted to review logs while on a very long flight from San Diego to London.  MP is locking up as soon as I hit the "Load Log" button under the Telemetry Logs tab, and also under the "Tlog > Kml or Graph" window when I hit "Graph Log."
I've uninstalled and reinstalled a few times, stepping back and forth between .58 and .59.  I then started to suspect problems with the .NET Framework, so uninstalled and reinstalled that via Win8's add/remove features.  I have tried installing 3.5sp via the download and when I click on the downloaded file, it doesn't seem to do anything.
I started focusing on the framework then, and cranked up a quick .net app (making sure to use v3.51 as the runtime in the IDE) and coded a button to open up the file dialog like this:
private void button1_Click(object sender, EventArgs e)
OpenFileDialog ofd = new OpenFileDialog();
ofd.ShowDialog();
label1.Text = ofd.FileName;
The file dialog opens fine.
Has anyone else run in to an issue like this, or does anyone have any suggestions on what else I can do?  Is a connection to APM required at least once before the review of any logs, or is that unnecessary?
Josh
  • Hi everyone,
    Im Trying to decide which way to go w8 or android tablet for the field,
    I would like to know if somebody has an experience of running mp on a w8 tablet and compared it with the droid planner app running on an android tab.
    Is mp on a tablet practical ?, can I replace the netbook with tha tab?
    Is it possible to have video on the android tablet via USB with an adaptor, ?
    Any very visible pro or con , to decide for one or the other ?
    Thank you very much for help,
    please wait a little longer. I think it will be loading.
  • Anyone have any thoughts?
