Hi all,
I have just received my APM2 today so I'm a new user.
I want the APM2 to send out the MAVLink messages to my XBee, which I believe is UART0 as per the usual setup procedure in the manual...no problems here.
HJowever, I ALSO want the same messages to be sent down one of the other UARTs (don't mind which), so an exact copy. As a secondary thing, it would also be nice if the APM2 was able to receive MAVLink messages from both ports but I don't know if this is possible?
So, how do I configure APM2 to send MAVLink down two UART ports?
Simon
Tags:
Permalink Reply by Simon Howroyd on May 23, 2012 at 11:57am ...just as a raison d'être, I will be sending the second stream to an onboard computer doing high-level control so it needs to be able to decode the MAVLink, make some decisions, and update the APM2. The XBee will run on the APM2 as normal with the GCS.
Permalink Reply by Tommy Larsen on July 1, 2012 at 4:41am Any luck on this issue ?
Tommy
Permalink Reply by Simon Howroyd on July 1, 2012 at 10:30am No mate not yet
Permalink Reply by Mohamed Zahana on March 23, 2013 at 4:44am I got a solution to this!!
Have you solved your problem?!
Permalink Reply by Simon Howroyd on March 23, 2013 at 5:40am No buddy no solution? What's your idea.
Permalink Reply by Mohamed Zahana on March 23, 2013 at 5:59am Very simple. If you have the
Permalink Reply by Mohamed Zahana on March 23, 2013 at 6:03am Sorry about the last incomplete message!
So If you have APM2, then you can add this line to your APM_Config.h:
#define TELEMETRY_UART2 ENABLED
and connect your telemetry device (e.g. Xbee) to the separate UART2 port on the APM2 (you will find it in a raw of 12 pins on the board side).
That's it, and enjoy transmitting/receiving on both USB and Xbee!
I hope that helped!
Permalink Reply by Simon Howroyd on March 24, 2013 at 3:40am Sweet thanks!
Permalink Reply by Mohamed Zahana on March 24, 2013 at 3:41am Did it work with you?!
Permalink Reply by Ufuk Irmak on Tuesday Hi Mohamed;
I tried your solution but it is not working. Have you any idea or do I need to add some code to the program
Permalink Reply by Søren Kuula on Wednesday Hi,
That will not work quite as expected.
If you see the ArduPlane/config.h there is the only place at all where TELEEMTRY_UART2 is read.
If enabled, USB_MUX_PIN will be set to -1 (and there are no other effects).
In system.pde you can see that this will kill the multiplexer UART0 port / USB.
A solution that I used is to find the hal.uartC->begin and gcs3.init lines in system.pde. These are oly compiled on the condition that USB_MUX_PIN<=0. That is not necessary. Delete #else above those 2 lins and put the #endif below where #else was. Now go and disable TELEMETRY_UART2 again so the mux will work again. Or better yet, delete all mention of TELEMETRY_UART2 and its setting the MUX port to number -1.
I have UART0, UART2 and USB serial working all of them!! UART2 runs at the SERIAL3_BAUD speed. The SERIAL3 (yes, three) name comes from APM1 days when the secondary UART was number three. UART0 goes to the UART0 port using SERIAL0_BAUD when USB is not plugged. It runs at 115200 and goes to USB when plugged in.
Regards
Soren
Permalink Reply by Mohamed Zahana on Thursday I got it working fine with an easy and fast solution. So currently I am using the USB to communicate with an external embedded computer (Gumstix), and I am using the Xbee to visualize the output on Mission planner!
The setup is really easy!
Simply you need to do two steps:
1- add this line to the APM_config.ino Tab
2- solder the pins on the side of the APM (UART0 & UART2 & +5v/GND)
Now connect your Xbee to these UART2 pins (you just soldered), and communicate using a baud rate of 57600.
REMEBER: Do not play with the mux. Leave it as you received it!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1280 members
179 members
16 members
182 members
86 members
Powered by
