my first big flight away
Hi to all
well, custom H alu frame, APM mini firmware 3.2 - GPS Ublox 6h, Qbrain 4x25, moteur Ipower 850Kv.
I start the quad this morming with auto mission 800 m. Wait for 7 satelites - I usualy get 8/9 satelites in our open field,
Started with Alt Hold, seems all good and when I engaged Auto, the quad went 90° and flight away.
I was unable to get it back, no responding to the RC. Thank to telemetry I found it back, very close to a lake.
The log send EKF error, fail safe EKF.... but the EKF_CHECK_THRESH = 0, so I understand that EKF is not acting.
One point very surprising : Z vibration get worst and worst. Never see this. I usually get very low vibrations.
Thank you for your advices !
Log attached
2014-12-14 11-10-14.log
  • Looks like your hdop was around 3 when you hit auto. That's not very good.
    Looks like the VCC [ which I think is the voltage feeding the controller from your BEC ] dropped to 3.8 or so a couple of times. I'm pretty sure it should be around 5. I guess your not using a power module just a BEC? The the log seems to be corrupted I can't even see rc in or rc out. What kind of radio and receiver are you using? Anyway I am not real good at reading logs just a couple things I notice. Just for the heck of it you might want to change and or double check all your wiring connectors. I had an issue once it acted badly sometimes other times not. Turns one of the 4 wires from the mag was pulling out of the connector. I think I'd consider a gps with a bigger antenna that might help with the sat count and hdop. I've had good luck with this [ this is for the pixhawk 6pos connection apm version uses a 5 which they sell as well ] http://hobbyking.com/hobbyking/store/%5F%5F55558%5F%5FUblox%5FNeo%5...
    But again... I'm no expert reading logs. Good luck.
    • I am using BEC from Qbrain 4x1 - I prefer that as separate UBEC because less cables mean less problems.
      I think the logs were corrupted because of the fall.
      I am using orange TX and RX
      Anyway, thank you for you rtime
      • Just FYI that's the same 4 in 1 esc I use. Your right less wires... nice. Hope you figure out the problem.
        ps send some of that warn air up to North America please :]
        • the fact is that we have currently a nice wind coming from south -> 24°c / 28° for tomorrow....  a pleasure to fly
  • undefinedI try to use kml to understand this flyaway but I cannot understand why the quad went 90° north as soon as I engaged auto and why it didn't response to LAND mode. It was 50 meters from me.
  • Randy, I just saw this :
    https://groups.google.com/forum/#!topic/drones-discuss/rR5CChipB6I
    So, I have 2 questions :
    • is EKF out if we are using apm 2.6 ? ArduCopter 3.2 adds a DCM heading check and an EKF (Extended Kalman Filter – Pixhawk only) check to catch flyaways caused by a bad heading estimate.
    • I put EKF_CHECK_THRESH = 0 - is it dangerous ?
    The fact is that I get in 2 days 2 majors incidents with 2 differents quads in a auto mission. One trying dronies mission with droidplanner - the quad went 180° opposite, right to a tree - and this flyaway with quad going 90° as soon as I engaged auto. And out of control.
    Thank you for your help.
    Google Groups
    Google Groups allows you to create and participate in online forums and email-based groups with a rich experience for community conversations.
    • No, there is no EKF for APM 2.6.  I think what you're seeing is more of an error in the log analysis program.  Those errors #16 and 17 should be labelled as INAV errors for APM2.
